Power Stop Brakes on 2003 f250 with the 7.3
Hey guys, figured I've been here for awhile and may as well do a thread on brakes. I just bought the truck and I've decided to upgrade the brakes. I bought a kit from a well known online vendor (cant say their name cause they arent a site sponsor). It came well packaged, and everything was there, it looks like it should be an improvement.
Weather was poor today, so i did not have a chance to install them, hopefully Thursday. The kit also included break in instructions, which was nice because i had no idea you had to break them in. Ill be doing a how to step by step on the install. I saw a few threads questioning their quality, so ill do a review afterwards as well. Lastly, Ill be doing a brake fluid flush sometime next week.
this kit even included the caliper slide pin covers, not bad for $321.00
I have these brakes on my work truck (2002 f-250 extended cab long bed 7.3) I tow heavy almost everyday (10-12K) and tow up and down steep grades. The brakes have done ok, but the rotors are warped and the venting holes are always filled with brake dust, that I have to drill out when I inspect them. Brakes have about 20K miles on them.
I don’t mean to be a Debbie Downer, but I hope those rotors don’t crack on you. I’ve seen cracked rotors at the holes at SCCA events (on super-light cars) and seen cracked rotors on a few street cars.
They look awesome but the “helps remove brake dust and outgassing” is just a wive’s tale.
— Dave
— Dave
— Dave
— Dave
Because motor cycles weigh, what, 600 pounds? Not much heat generated with light braking force.
Comparing motorcycle brakes to heavy truck brakes is ridiculous.
The only rotors that do not crack around the holes are carbon ceramic rotors, which is a $10,000+ option on a Porsche.
— Dave
— Dave
I've gone through a set of drilled and slotted rotors to completion (wore out) with no cracks whatsoever. That is in a big heavy E-350 towing a 7500 lb travel trailer half the time. Powerstop pads would go between 20-30k miles, but the rotors were more like 60k.
Can drilled rotors crack? Sure. I've seen solid rotors crack at track events, too.... rapid heating and cooling cycles require heavier brakes than what folks tend to put on their small cars.
fordmerc, you are definitely towing heavy, but I have a question for you. Did you replace your calipers when you the power stops were put on? Worn out calipers might be why you are warping rotors after 20k. You are towing a lot more than I do, and more frequently, so it could be that they just aren't up to your duty cycle, I'm just curious. Half of my towing has been in the Smokey Mountains, but I have my trailer brakes dialed in real well, and my travel trailer has a big wind area, so I'm able to slow down easier because of the drag. Even going down hill through Asheville (6% grade), I really don't have to ride the brakes heavily.
There is a wide range of thickness and material quality that plays a role here.
