stuck in first gear - Ford Truck Enthusiasts Forums
stuck in first gear
Old 08-22-2011, 07:34 PM
MichelleS MichelleS is offline
MichelleS is starting off with a positive reputation.
stuck in first gear
Hi, My husband replaced the clutch and slave cylinder in his 1996 f150 and now it's stuck in gear. The clutch works great and takes it out of gear but the stick is in neutral position and feels like it's locked in a gear. Does anyone know of a way to NOT take the whole thing apart again But get it out of gear?
Thanks, Michelle
Old 08-22-2011, 07:41 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
What do you mean by "feels like it's locked in gear"? does the shifter still move normally but its still in first or cant move the shifter...
Old 08-22-2011, 07:48 PM
When you depress the clutch the transmission spins. When you do not depress the clutch its locked in gear.
Old 08-22-2011, 07:51 PM
No the shifter is in Neutral position but it does not move.
Old 08-22-2011, 08:04 PM
octaneforce's Avatar
octaneforce octaneforce is offline
octaneforce is starting off with a positive reputation.
this happened to me and it ended up being the shift forks mis-aligned in the tranny. he must have taken the shifter off to drop the tranny, correct? did he remove the cover on top of the tranny with the three torx screws? take a look under that cover and see if you notice anything out of line. it sounds obscure but when you take the cover off you will see what i mean. you can actually pop the tranny in and out of gear with a screwdriver while the cover is off.
Old 08-22-2011, 08:24 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Quote:
I'd say you hit the nail square on the head with that!!! Even if he just popped the shift lever it can do the same thing!!!
Old 08-22-2011, 08:33 PM
He said thank you and you were correct on everything that you described but he is afraid of prying on something and breaking it? He doesn't know what to look for.
Old 08-22-2011, 08:35 PM
Thank you again OctaneForce. He's going to go look at it and see if he can figure it out. Much Much Much appreciated
Old 08-22-2011, 08:53 PM
your very welcome. let us know how it works out
Old 08-23-2011, 09:39 AM
It was a five minute or less fix thanks to you Hugs
Clutch stuck to flywheel GJBain 1973 - 1979 F-100 & Larger F-Series Trucks 25 10-09-2016 10:59 AM
Spongy soft clutch after clutch replacement Brian Fulcher 1987 - 1996 F150 & Larger F-Series Trucks 4 11-03-2015 12:02 PM
Thornhill broom beach sunday 10/13/13 sand_fiend S. California Chapter 1 11-09-2013 01:12 PM
96 f150 not shifting while engine is running MichelleS 1987 - 1996 F150 & Larger F-Series Trucks 4 10-24-2011 01:19 PM
Crankshaft Position Sensor michelle85 1997 - 2003 F150 2 01-18-2011 10:46 AM
Tags
1996, 1st, 2000, 2005, 94, f150, f350, ford, gear, repair, shift, sticking, sticks, stuck, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
