1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
v10 to v8 engine swap
Old 08-22-2011, 05:06 PM
deputyb's Avatar
deputyb
deputyb is offline
I am new to ford ownership (hopefully soon) and have a opportunity to buy a 99 F350 SD with a V10. the engine is shot and I was wondering if I might be able to put in a V8. I will not be using it to do the work of a V10 so I don't think a larger V8 will be underpowered. It has an automatic 4x4 transmission. It will mainly be used to haul firewood and maybe tow a 22' boat that a 5.7 L GMC or a 5.2 L Dodge handles fine. Is this feasible? I am guessing I will need the correct computer for the V8 but anything else? will the trans bolt up ok? new motor mounts? I can do an engine swap on the 95 GMC suburban with no problems, am I getting in over my head on a Ford engine swap V10 to V8? thanks deputyb Central IN.
Old 08-22-2011, 05:09 PM
barthel's Avatar
barthel
barthel is offline
Seems to me that with all the wiring harness and PCM changes you'd have to perform that it would be easier just to replace the V-10.
Old 08-22-2011, 06:11 PM
dkf's Avatar
dkf
dkf is offline
Replacing the existing V10 would be the easiest. You should be able to find a fairly low mile 2V NPI or PI V10 at a salvage yard for fairly cheap, check craigslist also. The 2V V10 is still being produced to this day for the E-series vans so a wrecked late model E-series is another place to pick up and engine. The next easiest swap to make would be to put in a 5.4l V8.(Basically a 6.8l with 2 less cylinders) You would need the complete wiring harness and ecm for the 5.4l to make things go easier.
Old 08-22-2011, 06:47 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
please dont put a V8 in that truck! V8's suck, if you want ill give you my V8 out of my 04 for the V10? Ill rebuild that animal and install her.
Old 08-22-2011, 06:49 PM
jc8825's Avatar
jc8825
jc8825 is offline
Swap it out for another V-10. You will appreciate the V-10 a lot more than the 5.4.
Old 08-22-2011, 07:02 PM
SuperDutyScaler
exactly! thats why i want to swap in a V10 so bad
Old 08-22-2011, 07:27 PM
Quad Racer's Avatar
Quad Racer
Quad Racer is offline
Yeah from what the 5.4 owners are claiming with fuel mileage, it would be easier to swap the V10. If you've already got the V8 it still wouldnt be worth it.
Old 08-22-2011, 07:28 PM
deputyb's Avatar
deputyb
deputyb is offline
Thanks ! sounds like a concensus has been reached.
faz ford
Engine Swaps
09-26-2013 07:12 AM
20015.4f350
07-01-2013 10:26 AM
danlee
11-23-2012 07:10 PM
bigolfordtruck
08-14-2006 09:42 PM
s1120
Engine Swaps
08-19-2004 04:55 AM
Quick Reply: v10 to v8 engine swap
