v10 to v8 engine swap - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-22-2011, 06:06 PM
deputyb deputyb is offline
deputyb is starting off with a positive reputation.
I am new to ford ownership (hopefully soon) and have a opportunity to buy a 99 F350 SD with a V10. the engine is shot and I was wondering if I might be able to put in a V8. I will not be using it to do the work of a V10 so I don't think a larger V8 will be underpowered. It has an automatic 4x4 transmission. It will mainly be used to haul firewood and maybe tow a 22' boat that a 5.7 L GMC or a 5.2 L Dodge handles fine. Is this feasible? I am guessing I will need the correct computer for the V8 but anything else? will the trans bolt up ok? new motor mounts? I can do an engine swap on the 95 GMC suburban with no problems, am I getting in over my head on a Ford engine swap V10 to V8? thanks deputyb Central IN.
Old 08-22-2011, 06:09 PM
barthel's Avatar
barthel barthel is offline
barthel has a good reputation on FTE.barthel has a good reputation on FTE.
Seems to me that with all the wiring harness and PCM changes you'd have to perform that it would be easier just to replace the V-10.
Old 08-22-2011, 07:11 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Replacing the existing V10 would be the easiest. You should be able to find a fairly low mile 2V NPI or PI V10 at a salvage yard for fairly cheap, check craigslist also. The 2V V10 is still being produced to this day for the E-series vans so a wrecked late model E-series is another place to pick up and engine. The next easiest swap to make would be to put in a 5.4l V8.(Basically a 6.8l with 2 less cylinders) You would need the complete wiring harness and ecm for the 5.4l to make things go easier.
Old 08-22-2011, 07:47 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
please dont put a V8 in that truck! V8's suck, if you want ill give you my V8 out of my 04 for the V10? Ill rebuild that animal and install her.
Old 08-22-2011, 07:49 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Swap it out for another V-10. You will appreciate the V-10 a lot more than the 5.4.
Old 08-22-2011, 08:02 PM
Quote:
exactly! thats why i want to swap in a V10 so bad
Old 08-22-2011, 08:27 PM
Quad Racer's Avatar
Quad Racer Quad Racer is offline
Quad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to all
Yeah from what the 5.4 owners are claiming with fuel mileage, it would be easier to swap the V10. If you've already got the V8 it still wouldnt be worth it.
Old 08-22-2011, 08:28 PM
Thanks ! sounds like a concensus has been reached.
1998 F150 4.6L that smokes when starting up Shorty2313 Modular V8 (4.6L, 5.4L) 2 12-16-2015 08:35 AM
1998 F150 4.6L that smokes when starting up Shorty2313 1997 - 2003 F150 5 12-08-2015 12:18 PM
Ford should've released the 3v V10 back in 2003 instead of 2005... vee10td Modular V10 (6.8l) 12 09-19-2011 12:39 PM
Engine Weight Info 4tl8ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 11-15-2008 09:00 PM
V-8 to V-10 Engine Swap dff 1999 to 2016 Super Duty 6 10-13-2008 03:10 PM
Tags
1999, 2001, 250, 54, conversions, duty, engine, f250, f350, ford, motor, super, swap, v10, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
