wvo and engine longevity
Old 03-29-2008, 11:47 PM
luvemhot's Avatar
luvemhot
luvemhot is offline
I am thinking of running wvo are there any concerns to the life of the engine? What do you do to elevate them? thanks for your help
Old 03-30-2008, 05:31 PM
AndysFords's Avatar
AndysFords
AndysFords is offline
At this point I'm still not sure, however, with the money I've saved running WVO in my two Old Fords, I could buy both of them two engines.
Old 03-30-2008, 05:53 PM
littledre1's Avatar
littledre1
littledre1 is offline
Check this out....
http://www.dinofuelalternatives.com/...inspection.php
50,000 miles on WVO and the injectors are perfect. That's not to bad.
Just make sure that you get good WVO and make REAL sure they don't put any wash water with lye in the WVO you pick up.
Old 04-03-2008, 03:04 AM
misnomer's Avatar
misnomer
misnomer is offline
Originally Posted by littledre1
Check this out....
Dino Fuel Alternatives: 7.3 Combustion chamber and injector reports after 50,000 miles
Thank you for posting that! I have been wanting to see something other than those photos of valves and pistons gummed up from using WVO. There are trucks out there with over 100k miles on them without problems, but the few that blew something are the ones you see photos of.
Old 04-03-2008, 09:01 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
If you are going to run WVO be sure to do it right, do the conversion.
The AndysFord and misnomer speak of are IDI, PowerStrokes are a different animal and much more sensitive to fuel problems. What works for IDI will not necessarily work in a PSD.
If you do not get your truck set up properly you could be looking at a new engine in a little while.
PM FN74 (Vegistroke) he is the forum sponser.
If you dont want to convert the truck then make BD with the WVO.
I have an extensive study done a few years ago on running WVO and the potential problems associated with it. It is too long to post here but I will e-mail it to you if you PM your addy.
Old 04-03-2008, 09:36 AM
luvemhot's Avatar
luvemhot
luvemhot is offline
Was your study with the 7.3 engines or the IDI?
Old 04-03-2008, 09:55 AM
Phydeaux88's Avatar
Phydeaux88
I did not do the study and it was on diesel engines in general so the findings will apply across the board. You can apply them to the IDI engines straight up but when you apply them to a PSD you should expect more problems at increased levels of severity.
Old 04-04-2008, 08:09 AM
luvemhot's Avatar
luvemhot
luvemhot is offline
Phy I sent you a pm with my email
Old 04-05-2008, 12:38 PM
Phydeaux88's Avatar
Phydeaux88
Loveem and misnomer study on the way
Old 04-05-2008, 02:47 PM
akghound's Avatar
akghound
akghound is offline
Tons of info
Checkout the resource area here Frybrid Vegetable Oil Fuel Systems
Then go to the forum, you will find more info there. I use it.
Ken Gardner
Old 04-07-2008, 10:46 PM
parkland's Avatar
parkland
parkland is offline
When it comes to questions like this, the my answer is always the same.
1. Clean WVO better than anyone tells you, or you read about.
2. Make DARN sure the oil is good and hot by the time it enters the engine.
If Super clean WVO reaches the motor, at 180+deg, and of course normal fuel pressure, everything will be ok.
Any variation of those things, trouble may come fast. I never had an oil analasys done when i was running WVO a while back, but thats a good idea.
PS, When I said filter, I meant filter - I build a home made filter, that the WVO passes through 20-30 newspaper pages. It dripped so slow it might take a day for 1 20l pail. Of course, heated up real good she would go quicker, but you should filter better than a grease filter or paper filter.
Old 04-08-2008, 11:55 AM
luvemhot's Avatar
luvemhot
luvemhot is offline
thanks Prarkland I was going to filter down to 2
Old 04-08-2008, 09:27 PM
akghound's Avatar
akghound
akghound is offline
What filter
What are you using for filters to get to 2 micron?
Old 04-08-2008, 09:55 PM
luvemhot's Avatar
luvemhot
luvemhot is offline
dont know yet that is what I was told to do. when I get started.
Old 04-09-2008, 07:08 AM
firemediceric's Avatar
firemediceric
firemediceric is offline
I use a GE whole house water filter that comes into play after some other filtering. That filter is rated 1-2 micron nominal. Nominal is a lot different than absolute, so I know it's not a true 1-2 micron. I put felt battery terminal washers at the ends of the filter element to reduce the WVO bypassing the ends. I also wrap all of the filters in several layers of paper towel to extend actual filter life.
I do not believe in filtering the WVO hot. Yes, you will filter the stuff quicker, but I believe it also allows more junk to pass through. I try to stay patient.
Quick Reply: wvo and engine longevity
