Zerk fittings
There are two zerk fittings on the steering linkage (I don't know the name) but if you jack up the front end and turn the wheels you will see both and gain access to the grease fittings. A long flexible hose makes the job easier. I bought an 18" and it's great.
Everything else is sealed. I also bought a needle fitting to put on the end of the grease hose and it allows my to puncture the ball joint boots and squirt in a little grease. I realize this isn't a solution, but it will help delay needing new ball joints will set you back close to a grand to have shop do uppers/lowers and an alignment.
