Fuse Box Slot 29 - Customer Access? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-22-2011, 02:48 PM
Rose Clifford's Avatar
Rose Clifford Rose Clifford is offline
Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.
Question Fuse Box Slot 29 - Customer Access?
I'm wiring some lights onto my rack on the bed and want to tie them into the fuse box, so I'm looking for a slot that is already wired but not used, and I see #29 is "Customer Access."
Does anybody know what this is?
also, does anybody have a list or diagram that has the color codes for the wires/fuse numbers?
Old 08-30-2011, 09:48 AM
anybody?
bump to top
Old 08-31-2011, 02:01 AM
4inchlovin's Avatar
4inchlovin 4inchlovin is offline
4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of
heres a bump for ya...
Jim has really good wiring diagrams
Old 08-31-2011, 07:41 AM
I just need a fuse that has power, im close to saying screw it and just wiring it ghetto style
Old 08-31-2011, 08:00 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
He!! John, i'd wire it from there. Gotta fuse, plugs' powered up, nothing else is ran from it..id say go for it. I might just find this #29 plug, and re-wire my gauges from it.
Old 08-31-2011, 08:06 AM
Quote:
my problem is figuring out which wire it is behind the fuse box. I have a couple of options on my truck that werent used, like heated seats for example....heated seats is a 30A fuse so it's overkill, but even if I did want to tap into a 10A fuse that wasnt in use I wouldnt know which wire it is.
What's the process behind taking the fuse box apart? I dont want to get too deep into it, burning something out would really tick me off.
Old 08-31-2011, 08:16 AM
timmyboy76's Avatar
Old 08-31-2011, 08:53 AM
Yes except I don't think that would fit under the fuse box cover
Old 08-31-2011, 09:10 AM
wuttrd wuttrd is offline
wuttrd is starting off with a positive reputation.
fuse
that is exactly what i used for my on board air. and it does fit under the cover in the cab fuse box.
Old 08-31-2011, 09:22 AM
Quote:
Interesting, looks like I [you] just found my solution....good thing there's an autozone 1/4mi away from my office!
Thanks,
I still can't believe nobody knows what the deal is with fuse 29, and that nobody has chimed in about the wire color codes.
Old 08-31-2011, 09:31 AM
i think that it is # 11 under dash that i used. i want to say it is for wiper and and wiper motor.
Old 08-31-2011, 11:21 AM
i found this, but the fuse numbers don't match up
2003 https://www.fleet.ford.com/truckbbas/non-html/2003/bb_pdf/200-202.pdf
2002 https://www.fleet.ford.com/truckbbas...l/2002/278.pdf
here is the manual i go by for my 03 7.3L
http://www.motorcraftservice.com/pubs/content/~WO3F23/~MUS~LEN/36/03f23og5e.pdf
this guide is similar, for the 02...to make sure there is no 6.0 / 7.3 confusion
http://www.motorcraftservice.com/pub.../02f23og5e.pdf
Dumb electrical question - 06 XLT #29 Fuse HearseDriver 1999 to 2016 Super Duty 7 06-26-2016 12:19 AM
Missing fuse box cover sachonez Ranger & B-Series 15 06-03-2016 05:25 PM
Which fuse slot for hardwiring a radar detector? BMWBig6 2009 - 2014 F150 3 01-13-2012 05:48 AM
Replace fuse links with blade fuses? BaronVonAutomatc Electrical Systems/Wiring 6 04-20-2010 07:38 AM
Customer Access Fuse #29? ASAP Rob.D 1999 to 2016 Super Duty 1 08-20-2007 07:17 PM
Tags
2003, 2005, 2006, 29, access, box, customer, duty, excursion, f250, ford, fuse, panel, slot, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
