New clutch, now screeching noise
I just installed a new flywheel, clutch disk, pressure plate, throwout bearing and pilot bearing on my 00 F-250 with a 5.4. Now as soon as I start it I get a constant low screeching noise. It doesnt matter if the clutch is pressed or not the sound stays the same. I didnt take any of the hydraulic system apart, just removed the slave from the transmission and left the line connected. I took the truck for a short drive and it shifts in and out of gear good. Does anyone have an idea what might be causing this?
The only thing I could think of was that maybe the starter needed to be shimmed since I put the new flywheel on. Thanks for any help, Ryan
RUJusten
1978 - 1996 Big Bronco
04-26-2021 01:33 PM
LastStarfighter
1983 - 2012 Ranger & B-Series
05-24-2012 10:48 PM
Newcomer
09-13-2011 07:24 PM
