Vinyl Glue - Ford Truck Enthusiasts Forums
Vinyl Glue
Old 08-21-2011, 09:47 PM
john fin john fin is offline
john fin is starting off with a positive reputation.
Vinyl Glue
Anyone know of a strong glue that will bond vinyl to plastic/nylon. My tractor seat separated from the back. I dont think that 3m weatherstrip(yellow) glue will be strong enough.
Old 08-22-2011, 11:55 AM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
I can't believe nobody took a stab at an answer for you. I'd maybe consider that Gorilla Glue. That stuff is unbelievable. What kind of tractor do you have by the way? I've got a Kubota M6800 and my dad has a MF 135.
Old 08-22-2011, 12:11 PM
cruisetopdown's Avatar
cruisetopdown cruisetopdown is offline
cruisetopdown has a good reputation on FTE.cruisetopdown has a good reputation on FTE.
3M has a high temp spray glue that might work for you.
w
3M
Old 08-22-2011, 02:30 PM
dawolverine's Avatar
dawolverine dawolverine is offline
dawolverine is starting off with a positive reputation.
Not sure what you have in america, but over here in the uk some of the 'impact' type glues are pretty good for this sort of thing.
Alternatively, the spray on glue that profesional carpet fitters use for sticking vinyl floors downwould probably do the job (just make sure you get the good stuff, not the cheapo rubbish!!)
What Kind of Adhesive to Use on Seat ? hombre292 1967 - 1972 F-100 & Larger F-Series Trucks 3 04-05-2013 04:38 AM
glue for rim cover ?? derfm 1999 to 2016 Super Duty 7 04-04-2013 09:16 PM
Abs headliner covering question learpilot 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-27-2011 01:38 PM
Help with interior door pannel install monster693 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 03-04-2010 08:39 AM
anyone ever used no glue vinyl flooring? Max1 General NON-Automotive Conversation 18 12-03-2005 10:51 PM
Tags
glue, seat, tractor, vinyl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
