GT40 heads - do I need a new cam?
I've been doing a lot of reading on this forum and it seems that swapping my stock heads (1984 351W engine - no idea which head casting) for a set of GT40 heads would really wake the motor up. If I did this, would I need a new camshaft, and if so, what's a good choice. Also, will the stock length pushrods work?
Thanks,
Frank
Thanks,
Frank
on
Both cams are a healthy upgrade from stock but still well within what the factory valvetrain can handle. The 234 cam is rated as producing strong low to midrange power while the 238 is a better midrange cam. Use the 234 if you haul a lot and have stock axle gearing and the 238 if the truck has more gearing.
You might look into some CNC ported factory heads (Powerheads is one source) or check around on craigslist for some aluminum heads. I see the GT40 heads for ~$300 a pair uncleaned and ~$450 a pair rebuilt here in Dallas all the time and used Edelbrock and TFS heads for $500-800 quite a bit.
Of course, fancy heads don't really show up much unless you've got a pretty heavy foot. Find some with 58cc chambers and it would help wake things up down low a bit more.
Isky's Mil-a-Mor cams are real nice for daily drivers and they've got a 262 cam that's strong if you like to goose it a bit. Either of the Comp cams Paul mentioned would be good.
So I finally got a set of GT40 heads that have been freshened up but I don't have any rockers for theses heads. Should I just use the rockers from my smog heads or invest in a set of 1.7, and if so, should I get roller rockers? I am going to go with Conan's cam recommendation of a comp 35-234-3. Also, should I invest in new pushrods?
Drilling out head bolt holes
Conan (and anyone else that has done the GT40 head swap)
I read that drilling out the head bolt holes can be done on a drill press. Should I just buy a new 1/2 inch drill bit? Is there anything special I need to do? I called my local speed shop and they want $100 to drill the holes, and can't do it for another two weeks. I want to do the cam/head swap this week (I start a new job on the 23rd and took a week off in between to work on the truck and my GTO). My buddy owns a speed shop and has a big drill press, so if we can do it ourselves, i figured I'd go that route.
Thanks!!
Thanks!!
on
Yes do it yourself on a drill press, cast iron is pretty soft so it won't be difficult just make sure the head is sitting flat on the gasket surface(make clearance for the valves) and that the surface is perpendicular to the drill bit in both axis.
P.S. Some of these heads are already drilled at 1/2" so check them first.
cjcathey2002
08-13-2002 09:02 PM
