'94 351w stock head/cam spec's?
Does anyone know what the spec's on the stock head's for a '94 351w is? Intake/Exhaust valve size? Combustion chamber cc's?
Int/ext valve lift? lbs srings?
How about spec's on the stock roller cam?
Comp Cams set me an email for a recommended cam from them. When I look up the spec's they gave me I can't find a match in any of my catalogs. I'm not sure what I would be getting, there SB Ford CAM's typically have .008 degree duration and the one they recommend for me has .006? More torque? Here is the spec they sent me.
>From: "Brock Hayse" <bhayse@compcams.com>
>To: <bpcarlin@cvtel.net>
>Sent: Wednesday, April 02, 2003 2:27 PM
>Subject: Comp Cams
> Based on the info. you provided about your application, I would
> recommend the part number and specs below:
> ***Please respond to the original letter.This will reduce reply time***
> SPEC CARD INQUIRY
> PART NUMBER 35-349-8
> ENGINE FORD 351 WINDSOR
> GRIND # FW XE264HR-14
> DESCRIPTION COMP. FLAT TAPPET CAM
> INT EXH
> VALVE ADJUSTMENT HYD HYD0
> GROSS VALVE LIFT .512 .512
> DURATION AT
> .006 TAPPET LIFT 264 270
> VALVE TIMING OPEN CLOSE
> AT .006 INT 22 62
> EXH 73 17
> THESE SPECS ARE FOR CAM INSTALLED
> AT 110 INT C/L
> INT EXH
> DUR AT .050 212 218
> LOBE LIFT .3210 .3210
> LOBE SEPARATION 114.0 INT MASTER ID 3610F
> ADVANCE 4 EXH MASTER ID 3611F
> RECOMMENDED CC VALVE SPRINGS
> Regards ,
> Brock Hayse
> Technical Consultant Ext .553
>Subject: Comp Cams
> SPEC CARD INQUIRY
> INT EXH
> DURATION AT
> AT .006 INT 22 62
> EXH 73 17
> AT 110 INT C/L
> INT EXH
> DUR AT .050 212 218
> Regards ,
> Brock Hayse
To find the information you want on the 351's specs, I'd contact Ford Racing. Their website is http://www.fordracing.com/performanceparts. Telephone # is(586)468-1356,or you can write to them : Ford Racing Performance Parts,44050 N. Groesbeck Highway, Clinton Township, MI.48036-1108. They've been very helpful over the years with the MANY questions I've had. They'll know everything you'll want to know about the stock specs of the 1994 351 roller engine.
dimora
176
04-26-2018 08:00 PM
ford5.8
15
10-09-2010 10:34 PM
CowboyFromHell
04-22-2009 11:08 PM
