Rear brakes feed line - Ford Truck Enthusiasts Forums
Old 08-21-2011, 01:31 PM
Pappys53's Avatar
Pappys53 Pappys53 is offline
Pappys53 is starting off with a positive reputation.
I am getting the 9in rear end ready to install. It has part of the rubber line that feeds the junction block on the housing. How do you get it off to replace it? I have tried to put vise grips on it but it does not want to turn. How do you get the brass block off.
Old 08-21-2011, 02:13 PM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is offline
BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.
The original blocks on these trucks were a separate piece and the hose screwed into it. From about the 60's on, the block is permanently crimped onto the hose. You replace the whole thing as an assembly. If your 9" is out of a newer truck, I'd guess that's what you've got.
Old 08-21-2011, 06:06 PM
Pappys53's Avatar
My rear end is out of a 72 ford pickup. So I need to change the whole block?
Old 08-21-2011, 09:09 PM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
What he's trying to say is that you will get a brand new block when you buy a new hose. They're permanently attached to each other in the factory and sold as one piece.
Old 08-22-2011, 01:05 AM
Quote:
'Zactly! What you've got doesn't come apart like the original setup did. You get a new block as part of the hose assembly.
Old 08-22-2011, 12:41 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Ach!
You don't: The brass junction block/rubber rear brake hose is a one piece assembly (1968/72 F100 2WD: C8TZ-2282-C .. Rear Brake Hose).
The block has a hole in it, the rear axle vent passes thru the hole, threads into the rear axle.
E-Fuel Questions-Getting my list together BBslider001 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-07-2014 12:12 AM
oil pressure sending/ gauge install d-day Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 04-17-2014 08:37 PM
fuel tank feed line question dyoungen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 10-11-2013 10:01 PM
Resetting Proportioning Valve XzXPatrickXzX 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 02-23-2013 01:38 AM
Can I plug 1/2 of my Master Cylinder? woodsofpenn 1987 - 1996 F150 & Larger F-Series Trucks 3 08-31-2007 09:16 AM
Tags
c8tz2282c
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
