2002 F-350 NO REVERSE LIGHTS ??? - Ford Truck Enthusiasts Forums
Old 08-21-2011, 10:24 AM
pete/ny pete/ny is offline
pete/ny is starting off with a positive reputation.
Seems I have no reverse lights for some reason.They were both working and no neither of them works.The other lights work ok just the reverse ones. I have checked the fuse and if I was told correctly it was under the dash in spot #38.Yellowish green 20 amp.It checked out ok. Is there maybe another fuse under the hood that I should look for? I do not have a manual as I just bought the truck from a guy and there was no manual with it. Thanks in advance for any help.
Old 08-21-2011, 10:47 AM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
The next thing I would check would be the reverse switch which closes when you put the truck into reverse. It might be out of adjustment or has failed.
Old 08-21-2011, 10:58 AM
bulla's Avatar
bulla bulla is offline
bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.
Are these the factory reverse lights?
Old 08-21-2011, 10:59 AM
Thanks Neal
Quote:
Thanks Neal- is this switch accessible by the fuse panel or buried up in who knows where?
Old 08-21-2011, 11:01 AM
bulla's Avatar
It's on the tranny
Old 08-21-2011, 05:02 PM
Factory lights
Quote:
Originally Posted by bulla View Post
It's on the tranny
Bulla- yes these are the factory reverse lights in the rear tail light assemblies.Is there an adjustment on this switch and you say its on the transmission itself, vorrevt.Thanks again.Always nice to being able to see what youre going to back into!!!!!!!!!! LOL!
Old 08-21-2011, 06:21 PM
bulla's Avatar
I think
It's an electric switch on the pass side toward the top. So have you checked for power at the rear?
Old 08-21-2011, 06:37 PM
nlemerise's Avatar
I can't tell you on adjustment... usually there is. Here is what I would do on FLAT GROUND. Put key in, turn to run position (DO NOT START). Put E-brake on and w/o engine running put transmission into reverse. Then get under and check switch...see if you have 12vdc coming into the switch. If you do, then try the output side of the switch. If nothing then the switch is either bad OR out of adjustment. Take a jumper wire and bridge the switch and see if the back-up lights come on. Also, did you ohm out the fuse for the back up lights? I have seen fuses that visually looked good, but were in fact, open when tested using a DMM. More than once, too!
Old 08-26-2011, 07:17 PM
Thanks
Thanks guys for the tips and help on this.Seems both bulbs were blown out even though the filaments still looked intact.I bought 2 new snap in bulbs and they both work fine now!
Old 08-26-2011, 09:01 PM
nlemerise's Avatar
Quote:
I'd be checking why both bulbs burned out at the same time...coincidence?
Old 08-26-2011, 09:11 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Or more likely, one burned out and wasn't noticed until the other went out, too.
Pop
Old 08-26-2011, 09:20 PM
nlemerise's Avatar
Quote:
Pop
Ahhhh you old guys are always thinking !
Old 08-26-2011, 09:38 PM
I just got the truck back last week from the bodyshop and thats when I noticed them not working.I went back today and was asking the Owner about the bulbs being both blown out.He said possibly one of his body guys did it accidentally when removing and installing the wiring harness near the trailer hitch when they were taking the tail lights out or putting them back in after painting the box.But whatever, they are both working now.
Old 08-26-2011, 11:17 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
On the bulb issue, I have noticed at work a lot of the non-working bulbs we are replacing are not b/c of a burnt filament. They will not light. I beginning to think the connection at the bottom of the bulb inside is not very good anymore and coming apart.
99 E-350 SD Reverse Light Failure AliceSML79 1968-2013 Full Size Vans 5 02-08-2016 07:43 AM
No turn signals enil01 1968-2013 Full Size Vans 6 01-05-2015 07:06 AM
87 F350 460 Trouble Shooting troupstree 1987 - 1996 F150 & Larger F-Series Trucks 13 07-09-2014 10:07 PM
reverse lights blowing fuse js32ryder 1999 to 2016 Super Duty 4 01-17-2014 02:06 AM
Reverse Lights / Fuse question jls8177 1999 - 2003 7.3L Power Stroke Diesel 6 03-12-2010 05:34 PM
Tags
1997, 2001, 2002, 350, 73, backup, f150, f350, ford, light, lights, reverse, switch, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
