You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hello, all. The farm I work on has an old 1990 or 1991 F 250 4X4. We used this thing for years and years and years.
About two years ago, it started acting up. every time the engine gets hot, it shuts down, and will not restart until the truck cools down. I'd hate to see them junk an otherwise usable truck... the thing has a set of three ton overload springs on it to haul seed and stuff..over something that may be an easy fix.
The motor in question is a 351 with fuel injection.
Thanks,
Mike
__________________
Mike Hartle
PA Chapter member
1975 F100 Custom 4X2, 302 V8 2bbl, FMX 3 spd auto
Hatteras Green Metallic, 44,000 original miles;
1971 F100 4X4, 360 V8 2bbl, 4spd manual, factory WARN hubs, metallic grey
I ran into a similar issue on a v-6 in a dodge dakota, turned out being the distributor. Might be a good idea to put some inline spark testers on and see what that tells you. The v-6 I had the issue with was throttle body injected so when pouring some fuel in didn't get it started I went and checked spark. I don't know if it would do engine damage but you could try spraying some carb cleaner or starter fluid in the air filter track and see if that'll do it. (Works on a diesel but its not smart...)
__________________
Joe- PA Chapter Member
2000 F350 4x4 S/c LB 7.3L, Auto meter gauges, Stock for now with some goodies on order!
1997 F250 4x4 S/C LB 7.3L, STR8 piped, 6637, 203* T-Stat, TS 6 Pos. Chip, EBPV gutted, Stancor GPR, BD Turbo housing & wheel, built HD E4OD w/ Billet TC, 5r110 trans cooler.
