'05 Freestyle A/C Compessor Repair - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 08-20-2011, 09:17 PM
rogerf100's Avatar
rogerf100 rogerf100 is offline
rogerf100 is starting off with a positive reputation.
If your A/C won't blow cold at idle or low speed but does cool weakly at highway speed, don't let the Ford dealer convince you the compressor needs to be replaced. The symptoms can fool the tech into thinking the compressor is going bad and is weak. What they don't tell you is there policy is to replace not repair a compressor. The compressor is a variable capacity type that uses a scroll valve to increase/decrease the capacity based on the load. If the valve sticks you will get the symptoms I described. The scroll valve is a $40 part and can replaced in about an hour or less after the system is evacuated. Most A/C repair shops are not familiar with this repair either and recommend compressor replacement. After replacing the valve the system will need to recharged with R134a refrigerant.
I repaired our '05 Freestyle myself. I found out about this repair from My Ford Freestyle - Ford Freestyle & Ford Taurus X Enthusiast Site in this thread complete with pictures My Ford Freestyle .com • View topic - warm a/c while driving in the city and this Youtube video how to change a scroll valve on an a/c compressor for a ford freestyle - YouTube
Debris in A/C - Clean/Flush vs Replacement BVespone Escape & Escape Hybrid 5 05-18-2015 06:28 AM
A/C blowing through defrost only-where are vacuum hoses??? kljlmr Aerostar 10 03-12-2011 10:23 AM
2006 Ford Freestyle A/C Question averdin Crossovers 1 07-28-2010 08:43 PM
What's With Ford and Their Filters? R-WEST Oil & Lubrication 7 11-18-2008 08:44 AM
Freestyle with Duratec 3.5 l? Scott_XLT Crossovers 5 11-06-2005 08:41 AM
Tags
05, 73, ac, blow, cold, compressor, enthusiasts, ford, freestyle, repair, scroll, stopped, truck, valve, weak, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
