Battery drain through brake switch? - Page 2 - Ford Truck Enthusiasts Forums
Old 08-22-2011, 07:43 AM
flathead255 flathead255 is offline
flathead255 is starting off with a positive reputation.
Petey, I stuck my head under the dash and everything looks clean and dry around the wiring and headlight switch.
That high/low beam switch looks good but the terminals are riveted on and swivel a bit, (seem a little loose). I don't see a direct relation but might follow up on that one anyway.
I think I may have caused the "Mega Ohm" readings accidently through poor practices. I've since discovered infinite resistance on both brake light switches if I keep my fat fingers off them while using the meter. I might have been pinching the poles between the probe and my finger last time.
At this point I've disconnected and reconnected things enough times that the problem is not present. I am suspicious of an extension wire that I had made from the OEM harness to reach the brake switch and I'm going to replace it today. Tomorrow is cruise night so I'll see if anything arises after I get back.
Thanks for all the input,
Old 08-22-2011, 11:27 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
LOL! Been making a living with my meter for over 40 years, and still catch myself doing that occasionally.
'88 4.9L no spark, among other electrical issues Rwm8082 1987 - 1996 F150 & Larger F-Series Trucks 3 01-30-2017 12:39 PM
Cant find battery drain alhauger 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-16-2016 08:12 PM
brake light switch Shane Carruth 1961 - 1966 F-100 & Larger F-Series Trucks 3 05-07-2016 06:19 AM
86 302 dual no start paulwjax 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 08-24-2015 07:07 PM
Cruise Control Problem on 2003 F53 kstaskon Electrical Systems/Wiring 5 05-15-2012 04:56 PM
Tags
2000, 90, battery, brake, break, draining, draw, e250, excursion, ford, green, light, night, problems, sensor, switch, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
