1994 F150 A/C blower problem
The A/C blows cold but when I switch to Max Air and then accelerate the blower stops. When I slow down the blower comes back on. It does not happen when in the Normal A/C position. I had a car do this before but it was happening on normal air and not max air. The car problem was a relay gone bad. Any ideas where to start checking?
You nailed it subford. Thanks so much. It was 104 today when I tested the repair. The vacuum tubing had started to crumble. I cut it off where it comes out of the bundle. Then I cut the tape off of the bundle and reconnected the vacuum line.Secured the bundle with tie wraps. I would have thanked you sooner but I got called into work right after I finished the repair.
minnesotafisherman
10-17-2012 11:08 PM
FarmingF250
02-15-2012 03:14 PM
Alec94F150XL
11-23-2011 09:38 PM
cliffrwarren
08-01-2003 01:57 PM
sg
11-02-2000 08:44 AM
