how to test for bad injectors? - Ford Truck Enthusiasts Forums
Old 08-20-2011, 10:30 AM
bebeard's Avatar
bebeard bebeard is offline
bebeard is starting off with a positive reputation.
hi all,
how can I test to see if my fuel injectors are bad or stuck open/closed?
can a novice remove and replace FI on a 2004 F250?
Thanks,
Old 08-20-2011, 03:58 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Need more info, but I'm assuming you're talking about a 6.0 diesel...
Must like the 7.3, it can be done in the safety and comfort of your own driveway, but in order to test you'll need one of these: Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
It will allow you to perform the same diagnostics a Ford dealer tool can.
Where you located? Someone may have one nearby and be able to help...
Old 08-20-2011, 04:15 PM
bebeard's Avatar
Yes, 6.0 Diesel.
I am located in Fayetteville, Arkansas
Old 08-20-2011, 08:51 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
There is no easy way to fully test bad cylinders, but good indication can be temperature measurements. I've been using infra-red thermometer and right now you can buy one for $9, while $25 buys one with laser pointer. When you spot cylinder more than 40F colder than the rest, you have a mis performing one. Usually I measure temperatures of exhaust manifold, since on newer engines the top of cylinder is not accessible.
Old 08-20-2011, 11:22 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 08-20-2011, 11:30 PM
BLADE35's Avatar
BLADE35 BLADE35 is online now
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
have you checked your FICM voltage
I think that you can run a cylinder balance test with AE like OP mentioned
have you scaned for codes
If you had one thats stuck open it would be pouring smoke out the tailpipe nonstop and could burn a hole thru the top of the piston not good
and there not to bad to change out if you have a little wrenching exp...
Old 08-21-2011, 06:35 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Quote:
Originally Posted by bebeard View Post
Yes, 6.0 Diesel.
I'm in Ft. Smith, just down the road and I have AE on my laptop. I also do some repair work.
How to which injectors are bad with buzz test? jstihl 1999 - 2003 7.3L Power Stroke Diesel 56 06-11-2016 12:22 AM
PCM wiring diagram injector 1 no signal... rch10007 Modular V10 (6.8l) 5 10-01-2014 06:42 PM
injector connector mike L Electrical Systems/Wiring 4 02-03-2013 11:37 PM
testing injectors simms63ss 1999 - 2003 7.3L Power Stroke Diesel 3 04-26-2011 07:32 PM
how to test injectors? bowedup2003 1999 - 2003 7.3L Power Stroke Diesel 19 03-22-2006 04:37 PM
Tags
19945, 60, bad, deisel, diesel, ford, fuel, injector, injectors, manifold, open, powerstroke, stuck, temperature, test, testing, thermometer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
