2001 Expy, cranks, no start, injectors not pulsing - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 08-20-2011, 07:16 AM
werewolflht65 werewolflht65 is offline
werewolflht65 is starting off with a positive reputation.
Ok, so here's the sit-rep: 2001 5.4 Expedition. Came out one morning, hit the key, engine just cranks. Fuel pump has a very abbreviated run, and pressure at the rail is a drool. Ran a jumper wire to the fuel pump, and it runs fine, with full pressure at check valve.
The problem is, the truck still won't start. It WILL run on ether. So, this kicks my problem to the injectors. All fuses for PCM/ECU etc are good. Fuel Pressure regulator is new.
What is wrong with this thing? 117,000 miles.
Old 08-20-2011, 07:57 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
What does the THEFT light do when the ignition switch is turned from OFF to RUN?
Old 08-20-2011, 09:04 AM
Quote:
Blinks like crazy, which according to the manual, means the anti theft system needs to be serviced? Whatever that means. How do you service an alarm?
Old 08-20-2011, 10:08 AM
It means that PATS prove-out has failed and the computer has disabled the engine.
Old 08-20-2011, 11:21 AM
Boat Tug Boat Tug is offline
Boat Tug is gaining momentum as a positive member of FTE.
Quote:
Don't know if this will help but if you have a System 3/4 Alarm you can reset it, read this post:
http://www.ford-trucks.com/forums/10...ml#post9770690
Edit: Just disconnecting the battery for 10-30 minutes may re-set the PATS system - worth a try.
Old 08-20-2011, 07:35 PM
No, we figured it out. The owner had left us his dummy key. It works all the locks and such, but lacks the chip. He's in Cali at a funeral, but we were supposed to move it to a tranny shop to get fixed. Kinda hard to do that without the chipped key....
Thanks to all who offered help.
2001 f250 v10 randomly dies Michael DeWiese 1999 to 2016 Super Duty 11 12-23-2015 08:49 AM
4.2 V6 Fuel Pressure Issue yasky69 1968-2013 Full Size Vans 2 12-22-2015 09:08 PM
Bad high pressure fuel pump? brcwelding 1987 - 1996 F150 & Larger F-Series Trucks 4 04-21-2013 06:44 AM
1997 7.3 won't start no fuel pressure Domino2205 1994.5 - 1997 7.3L Power Stroke Diesel 6 02-22-2012 11:30 PM
2001 f350 powerstroke constant running fuel pump dandef 1999 - 2003 7.3L Power Stroke Diesel 3 06-11-2011 04:40 PM
Tags
2001, 2007, 29, 30l, 46, bronco, expedition, ford, fuel, injector, injectors, pressure, pulse, spark, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
