Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-20-2011, 01:59 AM
pwright0001's Avatar
pwright0001 pwright0001 is offline
1995 Ford F-700
pwright0001 is starting off with a positive reputation.
Thumbs up Please help me .. from propne to gasoline
I have a 1995 F-700 with 7.0L propane engine from factory. i need to know what I have to do to switch it to burn gasoline. The truck runs great as it is but I can only go about 22 miles on a 20 lb. bottle. I know that because I ran out 3 times bringing it home the night I bought it. My gps system showed my route was 66 miles. also Will the high compression of this engine be a problem with regular gas ??
  #2 (permalink)
Old 08-20-2011, 02:03 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
Garage is empty, add now
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Why do you have a 20lb tank??? The main tank should be at least a 200lb tank? Is it missing? To convert it well you will need the entire EFI setup and a new fuel tank. The comp ratio of the engine is the same as gas.
  #3 (permalink)
Old 08-20-2011, 02:24 AM
1995 Ford F-700
I have a larger bottle that came with the truck. I didnt know if a carrburator could be put on it . did not know it was fuel injection. thanks
  #4 (permalink)
Old 08-20-2011, 12:21 PM
1995 Ford F-700
i have looked at system on truck seems to be impco 425 and the piece that mounts behind it has model b printed on it
Tags
1995, 70, engine, f700, propane, runs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
