Where's the obd1 port?? 1990 ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-19-2011, 10:52 PM
2002exPSD's Avatar
2002exPSD 2002exPSD is offline
2002exPSD has a good reputation on FTE.2002exPSD has a good reputation on FTE.2002exPSD has a good reputation on FTE.
I've looked everywhere for the obd1 port on my 1990 ranger. Can't find it anywhere.
Old 08-19-2011, 11:34 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Passenger side inner fender.. probably tucked under the fuse box or whatever that is over there hanging off the fender. I had the code reader hooked up to our '90 last weekend and that is where I found it.
Old 08-19-2011, 11:50 PM
2002exPSD's Avatar
Passenger side?? Really?
88 econoline :any OBD port BigDan1 1968-2013 Full Size Vans 5 07-24-2015 01:16 PM
OBD Port Location - 2008 Ford F250 AlbyVA 6.4L Power Stroke Diesel 2 12-19-2012 09:18 AM
OBD1 96 F250 460 Gasser question talock 1987 - 1996 F150 & Larger F-Series Trucks 2 08-29-2011 05:22 AM
2001 F150 OBD2 Port Problem b1corr 1997 - 2003 F150 6 11-02-2009 04:46 PM
test port (obd) isenegger 1987 - 1996 F150 & Larger F-Series Trucks 13 07-04-2009 03:07 AM
Tags
1990, annalizer, check, code, datalogging, engine, f150, ford, light, obd1, pickup, plugin, port, ranger, read, reader, tester
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
