In the gutter
Old 08-19-2011, 06:15 PM
bob55's Avatar
bob55
bob55 is offline
In the gutter
Help, I just got done digging enough fiberglass and cloth out of and under the rain gutter on my 55 to build a Vette. Above the windshield is pretty bad. I have seen effies with the gutter removed. What do you all think? I had thought about removing the front part and leaving on over the doors. Any feed back is welcome.
Old 08-19-2011, 07:34 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
Originally Posted by bob55
In the gutter
Been there,I feel for you.Just buck-up and pull yourself out of it! LOL
Welcome to FTE.
Old 08-19-2011, 07:52 PM
mOROTBREATH's Avatar
mOROTBREATH
mOROTBREATH is online now
The entire passenger side gutter is filled with silicone or body filler. So I take a look inside and find a ton of cloth type fabric. Left it alone for some other lifetime.
Here's the thing though, my dad never did work, and the previous owner never did any work...
...so that means all of that rust damage was done by at least the early 80's.....how can all of that happen in only 2X years? That's insane. Espcially since it appears to not have changed since it was "fixed".
Ehh, here in CA it'll last my lifetime so I'm leaving it alone.
Good luck getting yours back to new(or better!).
Old 08-19-2011, 08:00 PM
spurredon's Avatar
spurredon
spurredon is offline
Is that one of those bad ocean things? Up here the bottoms rust out so badly that it is refreshing to see a little rust on the top to even out the look!
Old 08-19-2011, 08:02 PM
spurredon's Avatar
spurredon
Welcome to FTE.
Steve, that is the most dramatic Buzzard yet!
Old 08-19-2011, 11:40 PM
mOROTBREATH
I don't know, rust up there frustrates and confuses me. Rust has to start from sustained moisture.
1) It never rains here. Ever.
2) I have no clue how a substantial amount of dust/dirt can accumulate there since nothing is up there now and I DD the darn truck!
3) The truck was built in Long Beach, CA, and had CA plates from '63 with tags on that plate to the early 80's--this truck has spent a good amount if not it's entire life in dry as heck CA......where would snow come from to rust it?
Rust on this truck has got me boggled.
As for guys like bob55 trying to fix these drip moldings, man what a heartache.
Old 08-20-2011, 06:12 AM
Harrier's Avatar
Harrier
Harrier is offline
Here is an excellent thread on drip rail removal.
https://www.ford-trucks.com/forums/9...l-removal.html
Fortunately I don't have to worry about that problem.
If you post some pictures, the experts here might be able to give some better advice.
Welcome to FTE.
Old 08-20-2011, 07:07 AM
petey shoes's Avatar
petey shoes
petey shoes is offline
dust/dirt will find every nook and cranny. add to that the condensation, which will have salt content from the beach, and there it is. rust! snow, (basically frozen rain) alone won't rust through the steel, unless truck is sitting in it knee deep for a very long time.
Old 08-20-2011, 09:44 AM
spurredon's Avatar
spurredon
Agreed! However, what comes along with snow climates is tempurature swings. It can be below zero at night and warm up in the 50's for a few days with the direct sun feeling warmer than that. That really causes things to sweat and shorten their life unless you have them in a heated area. The best I can do is to have them up stairs in the barn on a wood floor with plenty of hay bales setting around.
Old 08-20-2011, 09:52 AM
spurredon's Avatar
spurredon
I am not a metallurgist, but is it possible that the wrong filler rod was used during assembly (may be no rod was used, only spot welds,not real fimilar with the initial manufacturing process)or some other sort of dissimilar metal interaction?
Old 08-20-2011, 10:08 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,449 Likes on 1,396 Posts
I would venture to guess it spent a fair amount of it's early life on the coast. That moist, salty air will destroy most anything in a hurry. Maybe it was owned by surfer beatnicks and the truck was parked right on the beach all day, everyday for years. Dude.
Old 08-20-2011, 10:12 AM
ibuzzard's Avatar
ibuzzard
Originally Posted by 52 Merc
..... Maybe it was owned by surfer beatnicks ......
Some of my closest friends are surfer beatnicks.Gnarly!
Old 08-20-2011, 02:47 PM
spurredon's Avatar
spurredon
You gotta love beatnicks even if they can't surf!
Old 08-20-2011, 02:48 PM
bob55's Avatar
bob55
bob55 is offline
Oh, by the way all 4 corners shared the same"repair". The only difference is the corners were fill with spray foam before the cloth and resin was put on and molded to look like a 55 F-100.
MaineHomesteader
Car/truck Buying Advice
02-24-2016 09:48 AM
Pocket
25
11-03-2008 12:01 PM
edub32
1999 to 2016 Super Duty
03-09-2008 05:18 PM
pavlaker
01-12-2008 09:57 PM
homoudont
Paint & Bodywork
23
12-01-2003 04:45 PM
Quick Reply: In the gutter
