In the gutter - Ford Truck Enthusiasts Forums
In the gutter
Old 08-19-2011, 07:15 PM
bob55's Avatar
bob55 bob55 is offline
bob55 is starting off with a positive reputation.
In the gutter
Help, I just got done digging enough fiberglass and cloth out of and under the rain gutter on my 55 to build a Vette. Above the windshield is pretty bad. I have seen effies with the gutter removed. What do you all think? I had thought about removing the front part and leaving on over the doors. Any feed back is welcome.
Old 08-19-2011, 08:34 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Quote:
Originally Posted by bob55 View Post
In the gutter
Been there,I feel for you.Just buck-up and pull yourself out of it! LOL
Welcome to FTE.
Old 08-19-2011, 08:52 PM
mOROTBREATH mOROTBREATH is offline
mOROTBREATH is gaining momentum as a positive member of FTE.
The entire passenger side gutter is filled with silicone or body filler. So I take a look inside and find a ton of cloth type fabric. Left it alone for some other lifetime.
Here's the thing though, my dad never did work, and the previous owner never did any work...
...so that means all of that rust damage was done by at least the early 80's.....how can all of that happen in only 2X years? That's insane. Espcially since it appears to not have changed since it was "fixed".
Ehh, here in CA it'll last my lifetime so I'm leaving it alone.
Good luck getting yours back to new(or better!).
Old 08-19-2011, 09:00 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Is that one of those bad ocean things? Up here the bottoms rust out so badly that it is refreshing to see a little rust on the top to even out the look!
Old 08-19-2011, 09:02 PM
spurredon's Avatar
Quote:
Welcome to FTE.
Steve, that is the most dramatic Buzzard yet!
Old 08-20-2011, 12:40 AM
Quote:
I don't know, rust up there frustrates and confuses me. Rust has to start from sustained moisture.
1) It never rains here. Ever.
2) I have no clue how a substantial amount of dust/dirt can accumulate there since nothing is up there now and I DD the darn truck!
3) The truck was built in Long Beach, CA, and had CA plates from '63 with tags on that plate to the early 80's--this truck has spent a good amount if not it's entire life in dry as heck CA......where would snow come from to rust it?
Rust on this truck has got me boggled.
As for guys like bob55 trying to fix these drip moldings, man what a heartache.
Old 08-20-2011, 07:12 AM
Harrier's Avatar
Harrier Harrier is offline
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Here is an excellent thread on drip rail removal.
http://www.ford-trucks.com/forums/98...l-removal.html
Fortunately I don't have to worry about that problem.
If you post some pictures, the experts here might be able to give some better advice.
Welcome to FTE.
Old 08-20-2011, 08:07 AM
petey shoes petey shoes is offline
petey shoes is gaining momentum as a positive member of FTE.
dust/dirt will find every nook and cranny. add to that the condensation, which will have salt content from the beach, and there it is. rust! snow, (basically frozen rain) alone won't rust through the steel, unless truck is sitting in it knee deep for a very long time.
Old 08-20-2011, 10:44 AM
spurredon's Avatar
Quote:
Agreed! However, what comes along with snow climates is tempurature swings. It can be below zero at night and warm up in the 50's for a few days with the direct sun feeling warmer than that. That really causes things to sweat and shorten their life unless you have them in a heated area. The best I can do is to have them up stairs in the barn on a wood floor with plenty of hay bales setting around.
Old 08-20-2011, 10:52 AM
spurredon's Avatar
I am not a metallurgist, but is it possible that the wrong filler rod was used during assembly (may be no rod was used, only spot welds,not real fimilar with the initial manufacturing process)or some other sort of dissimilar metal interaction?
Old 08-20-2011, 11:08 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
I would venture to guess it spent a fair amount of it's early life on the coast. That moist, salty air will destroy most anything in a hurry. Maybe it was owned by surfer beatnicks and the truck was parked right on the beach all day, everyday for years. Dude.
Old 08-20-2011, 11:12 AM
ibuzzard's Avatar
Quote:
Originally Posted by 52 Merc View Post
..... Maybe it was owned by surfer beatnicks ......
Some of my closest friends are surfer beatnicks.Gnarly!
Old 08-20-2011, 03:47 PM
spurredon's Avatar
You gotta love beatnicks even if they can't surf!
Old 08-20-2011, 03:48 PM
bob55's Avatar
Oh, by the way all 4 corners shared the same"repair". The only difference is the corners were fill with spray foam before the cloth and resin was put on and molded to look like a 55 F-100.
rain gutter on roof inliner 1967 - 1972 F-100 & Larger F-Series Trucks 12 02-10-2013 11:10 AM
tips for removing drip rail trim 53-55 bigwin56f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 01-25-2011 04:54 PM
Rust Removal in the Rain Gutter Area, 53 f100... SunDown 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 10-15-2010 05:17 PM
Replacing Fascia Under Seamless Gutter aerocolorado General NON-Automotive Conversation 10 05-06-2006 01:14 PM
Gutters - regular or leaf-proof? anthony99 General NON-Automotive Conversation 10 05-06-2005 08:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
