Rebuilding 53 master cylinder - Ford Truck Enthusiasts Forums
Old 08-19-2011, 06:30 PM
Pappys53's Avatar
Pappys53 Pappys53 is offline
Pappys53 is starting off with a positive reputation.
I am rebuilding my single bowl mc on my 53 f100. I took it apart and have the rebuild kit. It looks real clean, no rust and I do not see any pitting. Should I still run hone it a little before putting the new kit in?
Old 08-19-2011, 07:46 PM
carnut122's Avatar
carnut122 carnut122 is offline
carnut122 is gaining momentum as a positive member of FTE.carnut122 is gaining momentum as a positive member of FTE.
I always have.
Old 08-20-2011, 05:29 PM
Pappys53's Avatar
Ok, I have the mc honed out. Putting it back together. Is there a secret for putting the holding clip back in that holds the internal parts in?
53 MERCURY M350 REBUILD KIT 53 merc m350 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 11-24-2016 12:39 AM
53 F-750 Brake Cylinder NHSPRET 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 10-08-2014 08:48 AM
53-56 vs 57-60 chassis dimensions Jrf100 1957 - 1960 F100 & Larger F-Series Trucks 1 01-02-2012 09:21 PM
53 f-100 front dics brake help fordsforme! 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 07-09-2011 09:35 AM
53 stock brake rebuild bluestang65 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 04-14-2011 03:52 PM
Tags
53, cylinder, master, rebuilders, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
