F6 used for a parts truck for F1 ? - Ford Truck Enthusiasts Forums
Old 08-19-2011, 04:59 PM
Cody_1948's Avatar
Cody_1948 Cody_1948 is offline
Cody_1948 is gaining momentum as a positive member of FTE.
Guys, I know a farmer who has a 1952 F6 (will post pics soon) that he not useing and it has an inline 6 flathead... I wanted to know if I could use it as a parts truck for the 48 F1 ?.. I was thinking I seen someplace that the f6 clabs and doors where the same ??.. If so I'd buy the F6 and use everything I can on my F1...
Thanks,
Cody
Old 08-19-2011, 05:06 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
From a body parts and trim standpoint, including interior pieces, everything is interchangeable between the big truck and the half ton. The only difference is the size of the wheel openings in the front fenders. They're considerably bigger in the F-2/6 trucks than the F-1. If you don't care about that, or have good/decent/usable F-1 fenders to use, you're golden.
Note that the grilles are going to be different between the 52 and your 48, so if you want to look correct, you can't use the nose, and the rear window is larger and the dash is different in the 52 cab, as well, so using the 52 cab on the 48 will be totally different, too. Now all you're left with that's interchangeable is the doors. If you don't mind your 48 looking like a 52, once again, you're good to go.
Old 08-19-2011, 05:08 PM
Cody_1948's Avatar
Old 08-19-2011, 05:09 PM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
Quote:
Thanks,
Cody
The cab, doors, and gas tank wil fit. The flathead 6 is heavier than the 6 in the smaller trucks.
Old 08-19-2011, 05:15 PM
52 Merc's Avatar
FYI, that's a 51, not a 52, and it has the deluxe interior and stainless window trim. Grab it if you can! The engine could be the 226 or the 254 flathead 6. Both are the same physical size, and have many interchangeable parts.
Old 08-19-2011, 05:39 PM
badger_hound's Avatar
badger_hound badger_hound is offline
badger_hound is gaining momentum as a positive member of FTE.
Quote:
I'm gonna bet it's a 254 as that carburetor looks like a Holley 897. If it is a 254, the head & block should have casting numbers that start with 8MTH rather than 7HA, right?
Old 08-19-2011, 06:27 PM
jmadsen's Avatar
jmadsen jmadsen is online now
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
Quote:
SOunds right.
Also Cody don't forget the 48-50 have the smaller back window, 51-52 have the larger back windows. dash is different gages etc.
Old 08-19-2011, 11:29 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
This should help:
Body Part Interchange Guide
Old 08-20-2011, 08:05 AM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
I could use that trim piece on the front of the hood. Its definately a 51.
radiator (Needed for my 48 F1) Any aftermarket work Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 03-26-2012 04:39 PM
Help me find waterpump, flathead 6 Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 02-21-2012 02:26 PM
Trade my f1 for f3 ? Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 02-04-2012 10:39 AM
1948 F1, More V8s or Inline 6's ? Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 01-20-2012 11:47 PM
6 volt golf cart battery wrk in f1 ? Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-23-2011 12:46 AM
Tags
1950, 1968, 292, 72, 897, f5, f6, firetruck, ford, fuel, holley, parts, sale, tank, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
