61-66, 73-9 parts f/s
#361
Category: Exterior - Body Parts
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '92+ Civic/EL & Del Sol, Prelude
Engine: Part suitable for gas truck
#362
I know I'm confused by Carmanico saying he doesn't have parts available in CamperSpecial65's ad. What's up with that? Whose tread is this anyway? I think someone should be banned for life. Hint hint. Lol.
#363
Firstly, I AM still on here... Secondly, I do have the fender bolt hole covers as well as 65 fender badges... Is your truck an F100 or 250??
Secondly ... Carmanico GET THE EFF OFF OF MY THREAD!! IVE TOLD YOU THIS BEFORE AND NOW IM TELLING YOU FOR THE LAST TIME!!!
GET OFF OF THIS THREAD!!! PERIOD!!!!!
Ive cleared most of the junk out of the mail... PM or email is easist way to reach me.
- cs65
- cs65
#366
- cs65
- cs65
#367
Do you have the radio support bracket that attaches to the bottom of the radio in the 73-79 F100/F150's? It is 'S' shaped and has a single bolt that screws into the bottom of the radio.
Steering column parts? Specifically the lower bearing with white plastic surround that keeps the steering shaft centered in the column? Turn signal switch?
Bench seat?
Dash bezel surround for 2 post radio?
6" lift springs?
Miscellaneous parts I don't know I need yet?
All of the above are to go into a 76' F100 with NP435, Dana 21(unfortunately), 351W with a 78' front clip.
Bench seat?
6" lift springs?
#368
I dont have any of those parts for your 76.... I have a dash bezel with the radio trimmed out nicely... The whole rectangular areas removed. I also have the large trim ring on the RH side of the dash in either black or woodgrain... These are metal vs plastic used in latter years.
The only other 73-9 stuff I have is a grille insert for 73-5 I believe and one for 76-77. As well as fender upper rub strip moldings.
- cs65
- cs65
#370
Hi guys, heres a parts list update...
The 57-60 stuff is still here and I REALLY want those gone badly!!!
67-72... I have THREE spoke steering wheels, turn signal switch, 67 hood side badges, tailgate mounting parts as well as handles. Horn ring and index plates as well... Ring is great but NOT chrome plated like earlier 61-66 but can be plated. Tail light lenses w/reverse lights for Styleside... ZERO Flareside parts for the 57-79 type beds.
I have bedside nameplates... Be specific w/yr and model...
I also have glovebox door name plates.
61-66.... No sheetmetal except valances top & bottom. Tailgate parts same as 67-72. Parking light bodies for 65-66 & their bezels, no lenses.
Dash cluster parts and metal bezels in addition to the lower trim bezel for 61-4 100-350 Custom Cab trucks. I have a radio speaker & grille as well as radio faceplate & antenna...No other radio stuff.
Bright headlight doors...64 bright grille & 66 battery tray
I also have mustard top coils as well. Some wiring harnesses be specic as to year and which harness you need... There are several per truck.
61-4 292 Ca emission air cleaner & carb spacer for same.
6 cyl carb... I believe its for 262 engine...1bbl.
Hood badges for 6&8's... No 61-2 side spears.
Side trim... Several 63-4 pieces, some w/clips. I do have a ' wrong bed' LH molding... Not perfect but decent and a tough find.
No 65-6 bed moldings.
Inside I have a pair of 64 ONLY upper door panel moldings... No screw hole at front. I have a few oddball pieces but no other full sets alone.
I do have an EXCELLENT ORIGINAL set of red door panels with full trim... I wont break them. But I do have a nice RH red panel w/o trim though.
No door pouches but I have trim rings.
Headliner trim and RH armrests in a few colors... No lefts...
Lastly I have an excellent set of 61-4/ F350 sill plates with rounded front end vs straight cut like early years... There were 2 variations on these...This set is fresh from sunny & dry California....
Lastly, I have a Flareside tailgate for 80-86 or 87... I foget which... This sucker is a 9.9 outta 10 with super paint and letter stenciling... White with red letters... Inside paint is pretty nice too... Came off a light wreck in RF..a super clean truck... A waste IMO...
Help me clear out some of this stuff guys!!!
On the 57-60 big stuff I prefer local(Wa/Or) buyers if possible as shipping big stuff is an arduous task.
Thanks, cs65
Thanks, cs65
#371
Thanks, cs65
Thanks, cs65
