61-66, 73-9 parts f/s - Page 9 - Ford Truck Enthusiasts Forums
Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Closed Thread
  #121
Old 06-10-2012, 07:08 PM
trlough7 trlough7 is offline
trlough7 is starting off with a positive reputation.
Category: Exterior - Body Parts
Price: $1
Private or Vendor Listing: Private Listing
Item Condition: Used
Engine: Part suitable for gas truck
Part fits:: 1961-1966, 1973-1979
looking for 73 f250 side toolbox latch and 73 camper special emblems
  #122
Old 06-12-2012, 04:05 AM
have 73 f250 camper special. looking for bed side toolbox latch and good condition 73 camper special emblems. can let me know at 520-241-1632.
  #123
Old 06-12-2012, 01:55 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
Im assuming you are referring to the handle assy on the door itself vs the catch inside the toolbox itself...
- cs65
  #124
Old 06-12-2012, 09:24 PM
46 ford flatbed's Avatar
46 ford flatbed 46 ford flatbed is offline
46 ford flatbed is starting off with a positive reputation.
Looking for the correct tailgate for my 63 flairside. The one that came with it is about 2" too tall. None worth buying here in spokane. Thanks
  #125
Old 06-20-2012, 03:09 PM
No Flareside tailgate for the early beds, only for the 80 to I believe 87 Flareside
beds...an EXCELLENT piece in original white w/red lettering.
Any more info on the tool box latch trlough ??
- cs65
  #126
Old 06-20-2012, 10:29 PM
78 Ford F150 460 78 Ford F150 460 is offline
78 Ford F150 460 is starting off with a positive reputation.
Do you have the alternator bracket and power steering pump bracket (that bolts to the water pump and block) for a 70's Ford 460? If so, how much?
  #127
Old 07-02-2012, 05:06 AM
no luck on the brackets 78 Ford...
I did however just score a very nice tailgate for the 57-66 Styleside bed...and I know where the bed is and IMO is worth saving from the crusher..
- cs65
I still have the jade green door panels for the dentsides...I also have a pair of
12 x 2 1/2" drums off of a 69 3/4 ton 2WD as well as loaded backing plates and 1 axle/spindle/radius rod if anyones in need...
Any more info on the dentside toolbox latch mentioned prior as I have a super clean one with the original key...
  #128
Old 07-04-2012, 06:06 PM
Cazman1955 Cazman1955 is offline
Cazman1955 is starting off with a positive reputation.
Do you have a steering column for a 1962 F100 with a 3 on the tree manual trans? I am also looking for the hood emblems for a 1961/62, looks like a arrow with the word FORD in it.
  #129
Old 07-05-2012, 10:09 AM
El Camino Man El Camino Man is offline
El Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to behold
Would you happen to have some manual locking hubs for a D50? Anything with a 30 spline axle will work though
  #130
Old 07-08-2012, 03:54 AM
No luck on the hood spears or column for your 62 Cazman..
no luck on the hubs el Camino man.
- cs65
  #131
Old 07-14-2012, 07:32 PM
more additions...early E series RH h/light door61-66 as I recall..
'Econoline' door nameplates in excellent condition
'SuperVan' door nameplate
Door locks(4)
Ignition switch/bezel for 71 type Econoline van
F-O-R-D rear door letters for the above van.
57-60 Fridge series truck stuff:
The aforementioned Styleside tailgate, 57-66 single wall Styleside bed
Chain and latch assys.
Front bumper(9.9 out of 10), painted
dash *****...white ...inquire as to which location on the dash
Headlight doors for chrome grille, rusty but straight as an arrow.
I still have several tailgates: mostly 64-66 Styleside type, 1 80-up Flareside
Flareside tailgate, none correct for the 67-79 trucks.
73-79 Jade green door panels
73-79 pickup and 78-79 Bronco dashpad, black
73-79 pickup, 78-79 Bronco RH dash surround, mine are metal vs the plastic ones used later on. 1 is black inside and the other is woodgrain.
67 F250 hood side nameplates
I have 2 OE brown starter relays, several OE voltage regulators, as wel
as recent aftermarket starter relays and voltage regulators(points ignition)
several 61-66 base model dash bezels, painted and chrome
2 of the hard to find lower dash **** trim bezels for 61-64 Custom Cabs
several pair of headliner trim for 64-66 with Custom Cab...various condition
grades.
Door glass for 61-66 F series, Vent frames...I have some good frames with bad pivots and/or bad handle shafts with glass for dirt cheap!! They need to go!!
292 Closed crankcase emission air cleaner assy.
Several 65-66 Custom Cab cluster assys as well as some parts for them.
1 pair of ORIGINAL red door panels for 64-66 F series...will trade for white set.
Several sets of door panel and dash pad trim as well as clips. I also have single pieces as well.
64 3/4 ton front hubs/drums...I havent miced the drums so unsure if those are good.
62-64 Upper valance panel as well as letters.
66 bright grille(2), 64 Bright grille(1), 65 Bright grille(1), headlight doors, bright and painted.
turn signal doors for 65-66
headlight door(LH) for 70-72 F series, nice and bright and nice black paint.
73-77 F series grille inserts
Various glove box door emblems for 67-79 F series
73-77 Super Camper Special fender nameplates, F350 fender nameplate
Transfer case ****
73-79 upper side moldings with rub strip(long bed)
73-79 Tie down hooks and screws/gaskets...no nuts for them
65-66 lower valance panel(2WD)
67-69 Ranger grille center nameplate/bezel assembly...1 blue, several red
67-72 lower fender or cowl 'Camper Special' nameplates...the hard to pull ones w/o destroying them...or pit easily.
61-66 column indicator for Cruise-O-Matic trucks(green dot)..NOS
light switches...65-up type...several, 1 62-64 type with fuse block part of h/light switch plug.
Fuel sending unit(several for in cab tank)61-72 type
Radios and speakers for 61-66 F100-350, 61-67 E series, 66-77 Bronco.
Door pouches for 61-66 F series, trim rings for them as well
Tilt column w/speed control , 78-Up E series...perfect wheel...tight column
Glove box liners for 65-66..with the step up in the rear.
battery trays..65 and 66
pair of front drums...67-72 with 2 1/2" wide shoes...I have axles, spindles for those...but not for too much longer as im cleaning shop and scrapping some stuff.
Im also seeking good rear wheel lip trim for my 91 Country squire wagon and clips...79-91 are all the same. dent free is whats needed mainly...wood grain as good as possible.
lastly, Im in search of a Marv Tonkin Ford license plate frame or two...he was a Portland, Oregon dealer and its where my 65 was sold new from.
Theres tons moreI have, feel free to inquire with needs...email is best way to reach me vs PM as it fills very fast.
Im after NOS trim or soft parts for 65-66...I need long bed moldings(i have a shortbed set NOS for trade.
firewall insulation pad
- cs65
email with needs..no parts too small...I am very heavy on trim fasteners and mldg clips for 65-66
  #132
Old 07-17-2012, 03:12 PM
PetesPonies PetesPonies is offline
PetesPonies is starting off with a positive reputation.
Looking for some 61-66 turn signal light assemblies.
  #133
Old 07-18-2012, 11:20 AM
Zalyia38's Avatar
Zalyia38 Zalyia38 is offline
Zalyia38 is starting off with a positive reputation.
I'm looking for a steering column and coupler for a '66 F100. I have the steering wheel, so I wouldn't need that. I guess I just need the lower part. New to this, so forgive my noobness
It's manual now and I'd actually prefer to do power steering, but not sure how to go about doing that.
  #134
Old 07-18-2012, 11:54 AM
I found my turn signals today at u-pull yard. $12!
  #135
Old 07-18-2012, 03:50 PM
what year are you working on ?? 65-66 is different then 61-64...I have 65-66 stuff including the parking light doors. I have usable 61-64 assemblies but definately not for a nice truck...driver quality.
- cs65
Closed Thread
Tags
61, 6166, 66, f100, ford, front, grills, lower, molding, parts, race, ranchero, suspension, track, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Lots of '73-'79 Parts - Parting out 3 1979 F350's EndorphinJunky Ford Truck Parts for Sale 26 01-12-2017 02:58 PM
66 LWB For Sale mangorockfish Vehicles for Sale 0 05-31-2016 10:48 AM
73-79 Ford Truck & 78-79 Bronco Parts-NEED SOMETHING?LOOK HERE! 351coupe Ford Truck Parts for Sale 282 02-11-2016 08:01 AM
61-66 Ford truck parts mal68ibu Ford Truck Parts for Sale 13 02-05-2016 10:36 PM
61-66 door latch abe 1961 - 1966 F-100 & Larger F-Series Trucks 0 01-13-2016 02:02 PM
