61-66, 73-9 parts f/s
#241
Category: Exterior - Body Parts
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '92+ Civic/EL & Del Sol, Prelude
Engine: Part suitable for gas truck
I'm looking for tab or black but I guess other colors are fine. They can be painted. As long as there in good condition.
Regarding the door panels. I'm looking for the upper ones that go around the door crank etc..
My email address is jmedina46406@yahoo.com
#243
91 turbo2, I do have lots of dash pieces... What specifically are you needing?
Post a visitors msg in my nick... R click my name, go to post visitor msg and lv email addy for fastest results
- cs65
- cs65
#244
66 F100 Steering Wheel and Shift Collar Red PS
Looking to purchase the upper half of the steering column in original red. Previous owner did a PS conversion and used a late model shift collar and wheel. Any info you can give me on whether its possible to go back to original given PS conversion would be helpful also! Don't know if they made PS version in 66 or later that could work!
Thanks,
Lawspawn
Thanks,
Lawspawn
#247
The steering wheel is the same type you see in Carpenters catalog...mine isnt red either though...If the column you have matches the primary interior color(red, blue, green, beige) its an original most likely...if its black it could be original as well...but black wasnt one of the color keyed colors available...it matched the bench seat and floormat typically.
Post your email and i will send you a pic of the indicatior which was used with automatic transmission equipped trucks...all were Cruise-O-Matics.
- cs65
- cs65
#248
Thanks - I am at erik.luckau@aes.com.
This forum and you guys are great!!! I am going to try to reconvert this myself even though I haven't so much as replaced a starter motor in 10 years! I am hoping that the column is stock (did you see my picture in the Lawspawn album?) and I can just replace from the shift collar up and re-hook up the linkages. As I understand it, power steering components all start from the gearbox on and are not affected by what is happening in the column. Is that right?
Thanks,
Erik
Thanks,
Erik
#250
I was thinking of those metal pieces that are above the glove box. I think they are a set of 2 or 3?
#252
Update...
Heres an update as to what I have for sale...keep in mind I have tons of fasteners and small nitpick type things typically tossed when repairing at times.
I have very little engine stuff and what I do have is FE only, mainly 352.
Dentside stuff: Jade green door panels, 1 armrest and 1 fingertip cup
Black dashpad
Sport steering wheel w/horn button
racetrak trim, various locations, have Supercab pieces
Upper tailgate molding...the huge black puppy above handle
FORD tailgate panel, not perfect but too good to toss
4WD transfer case boot, trim ring and ****
toolbox latch w/key
Grille inserts, 1 side each of the 2 early versions
78-79 Argent h/l doors
lighted visor vanity mirrors, red, tan, black
bed side molding, 8' w/rub strip
misc lower ribbed trim, inquire w/location on truck
Super Camper Special nameplates
Glovebox door nameplate, Ranger XLT, etc.
Bumpside stuff: Camper Special lower fender emblems
in cab tank fuel sending unit
glove box door nameplates, Ranger, etc
Ranger bedside nameplates(1970)
Sport Custom name plate, single piece style for bedside
Custom nameplate for bedside
tailgate hinges, side straps, handle,
Hood F250 nameplates('67 only)
Horn brushes(3 spoke wheel style)
Horn button, retainer
Starter relay, voltage regulator
70-72 Bright finish LH h/l door(good paint)
Misc mirror fasteners/brackets.
61-66 stuff: Red upper door panels..9.5/10
66 bright finish grille, 9.5/10
64 Bright finish grille, 9/10
65 Bright finish grille, 7/10
Bright headlight doors
steel headlight doors
65-66 upper grille panel/header panel
correct 64-66 tailgates, various conditions, all at least 8/10
**prefer local pickup only**
LH 2WD style fender, OE paint in super condition 9.5/10
Door glass...$3 each...Im tired of looking at it.
62-62 upper valance panel
F-O-R-D letters, 62-64 and 65-66 styles
armrests, RH side mostly, 1 green, several tan, several blue
upper door panel trim, sets or individual pieces, various cond.
Vent windows with or w/o frames..if you need glass only, I
have those in bad frames9pivots bad)
I do have some good assemblies as well with glass too which
makes for easier installation.
fender nameplates, 65 and 66 F100 and F250
F100 innie bottlecaps(1 pair)
F250 innie bottlecaps(no stainless)
West coast Jr mirrors and fasteners/brackets
Outside door handles, door handle buttons
wiper arms
t/light lenses, t/light bodies(64-66 Styleside)
Bedside toolbolongbed)
t/gate hinges, side straps, handle bezels, etc
Headliner aluminum trim
Door sill scuff plates, 61-4 and 65-66 styles
light switches, voltage regulators, starter relays, battery tray
and hardware
throttle cables
carb spacers(FE 2bbl)
Y block water pump/heater hose engine fittings
hose clamps(OE style, tower and wittek type(fuel fill tube
style)
dash *****
speaker grilles, defroster grilles, dash end cap parts
padded visors, RH hardboard visor
Fuel sending units
fasteners fasteners fasteners...chrome interior trim, body
sheetmetal, etc etc...lots of the specialty use/location type
fasteners
speedo clusters, bezels(65-66 sweep as well as 61-66 round
round speedo cluster parts/lenses/cardboard inners
61-64 Custom Cab lower switch trim panel(between column
and cluster bezel, says Custom Cab on it
some wiring harnesses...65-66 washer setups as well
Fridge stuff: front bumper, 59-60
lower aluminum grille, 1960
Chrome upper grille, 1960, 8/10...no rust through
57-60 core support...minimal rust in lower channel area 8.5/10
LH headlight door, 1960
vent cables, 1960 style(white *****)
headlight switch, 1960
dash *****, white, various locations
wiper pivot bezels/nuts
inside door handle
If you dont see it here ask...no power steering or d/b conversion parts at all
- cs65
Black dashpad
toolbox latch w/key
wiper arms
and hardware
throttle cables
style)
dash *****
Fuel sending units
fasteners
inside door handle
- cs65
#253
Edit: The 62-62 upper header/valance panel mentioned above should
read 62-64...
I also have a 66 F100/250 2WD battery tray.
OE mustard top ignition coil/bracket
- cs65
read 62-64...
- cs65
#254
'73-'79 race track molding
Hey Camper I'm having trouble navigating the site- but I am interested in the 2 race track moldings for the alcove in the bed (the rubber strip ones). My email is fordnutz6679@yahoo.com. thanks!
#255
Lawspaws, I didnt see any pictures of your truck on your page at all...if you can email me a photo or two that would be appreciated so i can see what you are in need of. Or PM me your email address if that would be easier for you.
91Turbo, PM me your email address or email it so we can discuss the dash trim more as I do have those 2 pieces.
- cs65
- cs65
