61-66, 73-9 parts f/s
#226
Category: Exterior - Body Parts
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '92+ Civic/EL & Del Sol, Prelude
Engine: Part suitable for gas truck
#229
Scuttlebutt, bigwheel, no luck on either of those...I will keep an eye out for those.
I do have a dash speaker though for you scuttlebutt..email or PM with contact info.
- cs65
- cs65
#231
mint51, I do have an excellent styleside tailgate...As to the door...are you working on a 57-60 or 61-6 style truck ??
post your contact info or PM me with it and i can send you pictures etc.
- cs65
- cs65
#234
a pleasure talking to you Tom :-)
As for the score of the day times 5...
how about 2 pair of lighted vanity visors...which gives me 3 sets...red, black and beige
I got an excellent alternator or oil pressure gauge bezel...gauge isnt bad(alt) but needs needle painted...
I still have a pair of jade green door panels for 73-9 F100-350 and 78-79 Bronco.
I also have a Sport Steering wheel with horn button for 78-79 F100-350 or
Bronco...
black dashpad for 73-79 F series and 78-79 Bronco
I also have a 57-60 radiator core support...not perfect, but very good condition for the most part...the lower portion needs minor rust repair.
Ive also got a chrome grille as well as the aluminum lower grille for a 60...
I also have Super Camper Special emblems as well for the 73-77 trucks
As well as the Camper Special emblems used on the fenders on the 67-72 trucks...
a real nice bright LH headlight door for 70-72
bright headlight and t/signal doors for 61-66 and 65-66 respectively
Painted front bumper for 57-60f100-250
Vent cables for 57-60(off of a 60 and has white *****)
62-64 upper header panel
64 bright grille
66 bright grille
64-66 padded visors
61-66 interior door trim for the plastic upper door panels
61-64 all, 65-66 F250 4WD, 65 F100 4WD, F350 door sill plates
65-66 door sill plates
65-66 sweep speedo clusters/cluster parts
61-66 metal dash bezels..painted, chrome, with or w/o extra gauges
61-66 round speedo cluster parts
61-64 all, 65-66 6 cylinder hood badge(gear & lightning bolt)
61-66 headliner trim
78-79 headlight doors
73-77 grille inserts
68-69 Ranger grille center emblems/bezels
67-69 Ranger bedside nameplates
70-72 Sport Custom emblem
67-71 Horn ring(argent color)
65-66 FE engine throttle cable, F100-250 2WD trucks
65-66 fender nameplates..
67 hood side nameplates
80-86 Flareside tailgate
65-67 window washer bags(blue)
61-66 3/4 ton bottle cap hubcaps
61-66 Custom Cab stainless windshield reveal moldings
73-79 race track left fender molding
73-79 upper side moldings w/rub strip..various pieces incl. Super Cab
65-79 various owners manuals
64-79 tailgate hardware(sup't straps, hinges, handles, fasteners, latches
If you need something not mentioned, inquire within...no engine parts except mustard top coils and core 65-66 AutoLite 2100 carb cores and NOS exhaust butterfly valve for LH side(FE engine, 65-67)
- cs65
Bronco...
64 bright grille
66 bright grille
64-66 padded visors
- cs65
#236
Hey cs65 -
I'm looking primarily for a radiator core support for my '63 uni. Do you have one and how much extra to ship to MN? Also on the lookout for a pair of sill scuff plates. Thank you for your time....
#238
Hi Camperspecial65, I am needing a tailgate for my 66 Camper Special. I also need gauge, it is the far right one that reads "Amps" or "ALT" or something like that. Can't remember off the top of my head.
I'm also looking for whatever I'll need to convert her to front disc brakes and power steering.
Could also use the pads that go on the doors, behind the arm rests, door handles and window levers. Not the zipper map pockets.
Look forward to hearing from you.
Joel
Joel
#240
Tigger, I have most all of that stuff...do you need a certain color armrest ? Are you needing the metal access panels at the bottom of the doors or the plastic ones around the window cranks etc. ??
post your email addy or leave a visitor message...same as PM except the visitor message choice is further down in the same popup you see when doing a PM...
- cs65
- cs65
