Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State/Prov):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Private or Dealer Listing:
Location (State):
61-66, 73-9 parts f/s
Old 09-04-2012, 08:40 PM
kylesandy64's Avatar
kylesandy64
kylesandy64 is offline
Category: Exterior - Body Parts
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '92+ Civic/EL & Del Sol, Prelude
Engine: Part suitable for gas truck
If you have the rub strip id say I might as well go ahead and get it
  #182
Old 09-04-2012, 08:41 PM
kylesandy64
Also.. do you have mirrors for the same truck?
  #183
Old 09-04-2012, 08:42 PM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
no...im referring to the type of molding...the base type of trim was a narrow aluminum strip with a raised rib
The other type is alot wider and has a rub strip in the center of it
- cs65
  #184
Old 09-04-2012, 08:45 PM
kylesandy64
What is your email? I will send you a pic of the truck I'm restoring I'm not sure what kind of trim it is honestly this is my first dentside
  #185
Old 09-04-2012, 09:44 PM
kylesandy64
I think it is without the rub strip
  #186
Old 09-04-2012, 10:05 PM
pwielage's Avatar
pwielage
pwielage is offline
Hey CS65, sorry I missed your prior messages. I'm still interested in the parts we discussed, let me know if you still have them for sale.
  #187
Old 09-05-2012, 06:51 AM
Leoman66's Avatar
Leoman66
Leoman66 is offline
Originally Posted by camperspecial65
No RH fender...only LH for 61-66
i sent you an email jazz...did it end up in the bulk mail possibly ?
I do have an upper molding for the dentside...are you needing with or w/o the rub strip ?
- cs65
hey bud did you recieve my contact info regarding side tool compartment box? you stated you had one is it still available?
  #188
Old 09-06-2012, 02:25 PM
Slow Joe's Avatar
Slow Joe
Slow Joe is offline
Looking for the arm for outside truck mirror for my 1965 F100. Don't need the bracket, pivot, or mirror, only the 3/4" tubular arm with the square end where the mirror bolts through. Let me know if you have one Thanks
  #189
Old 09-09-2012, 07:13 AM
michguy2009's Avatar
michguy2009
michguy2009 is offline
61-64 f-100 parts
Hello,
im looking for a rad core support, inner fenders, the stone deflector above the front bumper, and outer front fenders. My f-100 is a 1964. i think the body parts are all the same for 61-64. Got any of that? if you do what you want for them ? here is my number 313-300-1176. my email address is michguy2009@gmail.com.
  #190
Old 09-09-2012, 07:14 AM
michguy2009
Hello,
  #191
Old 09-09-2012, 02:51 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Rusty_Old_F250 is offline
Hi Don, did you get my PM? I'm looking for a set of alternator brakets.
Thanks
Sam
  #192
Old 09-19-2012, 04:59 AM
camperspecial65
Hi guys...I have been slammed with stuff...parts sold from here as well as life in general...and it wont be slowing down for a couple weeks at least...at which time I strongly anticipate having more goodies for the 57-79 trucks depending on what I find in my travels.
As to the requests...I still have the bedside toolbox
For your 64 michguy2009 I have a really nice LH fender off of a 66...beautiful white paint...has a very very light pancake on the side...i didnt even notice it until it was off, washed and I was putting it away...a mint piece aside from that.
I THINK I have a gravel shield for the 61-64 trucks...no core support or fender aprons though.
Rusty...I got your PM...I know Ive got part of the setup, but need to do more digging for the rest of it...
Slow Joe...which mirror type are you working with?? The larger type used on 65-66 CS trucks originally?? if so I am pretty sure Ive got an arm...are you needing fasteners ?
The bumpside Ranger gastank moldings are gone as are the bumpside CS fender emblems. I still have a couple Ranger grille emblems though...
I also have OE vacuum advance lines and fuel lines for the FE engines in 65-66 for sure. I THINK the fuel line is the same through 72 on engines with the 2100 carb.
I have a nice pair of Custom emblems used on the 70-72 as well as Sport Custom n/plate used on 70-72...the one piece type.
I have XLT n/plates used 70-72
Ranger bedside nameplates used 67-69
Super Camper Special fender n/plates...both part numbers..
in cab cargo light switch, 73-79
Rear and bed side reflectors used on 67-72 on F series and E series
70-72 LH h/light door
78-79 headlight doors in argent
mustard top coils
plastic battery hold down bracket
In cab tank fuel sending unit, 61-72, 73-77
Transfer case lever ball
292 water pump bypass fitting and t/stat housing
heater hose nipples for 292 engines
Air cleaner assy for 292 2 bbl WITH CLOSED CRANKCASE BREATHER
FE 2100 phenolic carb spacers
OE breather to spacer hoses used on FE engines from breather to rear port
in spacer
core 2100 carbs and parts
65-66 FE throttle cables
clutch pedal thru floor relay rods...various applications
Z bar from 64 Y block 2WD with both pivot brkts
Z bar pivot brkts for 65-66 FE
I still have the dentside dashpad in black that I thought would have been gone fast...Ive had it for over a year...
I also have several of the Warranty Facts tri foldouts used in 1969 model year rigs...covers all Fords...cars as well as trucks including E series vans.
Lots of dash ***** for 61-66 trucks...a few inserts as well
6 cylinder throttle cable ...65-66 trucks
padded dash trim...running low on clips for the front pieces and am out of clips for the rear stainless mldg.
door sill plates for 61-64, all or 65 4WD trucks and F350 and up as well as 66 F250 4WD and F350 and up
Several fender namplates for 65 AND 66..some w/o inserts
glove box door nameplates for the bumpsides and dentsides
RH dash surround trim for 73-79, woodgrain and black insert finish, potmetal pieces.
Dentside deluxe upper tailgate trim panel assembly
race track trim for LH fender
upper bedside moldings...with and w/o rubstrip for upper level trim trucks as well as base models
tailgate handles, escutcheon plates and screws for 64-72 gates
dentside toolbox latch assy WITH key
Jade green dentside door panels. one finger tip cup in jade green
73-73 grille inserts
65-66 t/signal doors
61-66 h/light doors in steel as well as bright finish
headlight retaining rings for 2 headlight trucks and cars..round lamps
headlight buckets for 2 headlight trucks..round lamps
As usual, if you dont see it here or in my prior edits/posts, inquire as i have lots of small parts and specialty fasteners as well.
- cs65
  #193
Old 09-19-2012, 05:48 AM
tanman722001's Avatar
tanman722001
tanman722001 is offline
You have any pics of the dash pad?What are asking for it?What you asking for the dentside toolbox latch assy WITH key?And the RH dash surround trim for 73-79, woodgrain and black insert finish, potmetal pieces.And which tailgate trim panels?
  #194
Old 09-19-2012, 06:25 AM
kylesandy64
How much for the dashpad for dentside?
  #195
Old 09-19-2012, 07:23 AM
scott79's Avatar
scott79
scott79 is offline
79 door panels
Hey, I am looking for a good set of 79 black door panels with the fake wood grain inserts in them. Got any? If so, price and condition? thanks man!!
Quick Reply: 61-66, 73-9 parts f/s
