61-66, 73-9 parts f/s - Page 12 - Ford Truck Enthusiasts Forums
Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Closed Thread
  #166
Old 08-18-2012, 06:56 AM
jazz jazz is offline
jazz is starting off with a positive reputation.
Category: Exterior - Body Parts
Price: $1
Private or Vendor Listing: Private Listing
Item Condition: Used
Engine: Part suitable for gas truck
Part fits:: 1961-1966, 1973-1979
do you have the kick panel vents for a 66 and also visors I need everything for them
  #167
Old 08-18-2012, 01:02 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
I have the vents... Are you seeking padded visors?
- cs65
  #168
Old 08-18-2012, 09:12 PM
visors
no the visors done need to be padded i just need everything.
  #169
Old 08-19-2012, 08:23 AM
low64's Avatar
low64 low64 is offline
low64 is starting off with a positive reputation.
need the letter "o" for my 64 f-100 grill/front(under hood/above grill).. and door panels w/ arm rests..have all the trim for the doors..just missing the panels w/ arm rests..
  #170
Old 08-20-2012, 01:59 PM
Jazz...I got you covered on all of it...email me direct for pricing, etc.
low 64...I have an 'O'...what color door panels/armrests are you needing ??
- cs65
  #171
Old 08-20-2012, 02:31 PM
pwielage pwielage is offline
pwielage is starting off with a positive reputation.
Do you have the chrome trim for the passenger interior door panel on a 65-66 (specifically the tight elbow towards the rear of the door)?
  #172
Old 08-20-2012, 02:41 PM
Edit/update....
The fridge series grille I have is a chrome/aluminum 1960 grille...I believe this will fit on a 59, but is a different pattern...less of a 'mesh' look over the '59. I have both upper and lower and is separated (no easy feat).
I also have both L and R vent cables with *****/bezels off of a '60 in addition to other dash ***** for them along with a headlight switch for 1960.
I have lots of emblems/nameplates in various conditions for most years from 57-79...not all...but most...driver quality to really nice originals..no V8 Hood badges for 61-66...I do have a very nice original gear & lightening bolt type though used on all 61-64 and 65-66 6 cylinder trucks.
I also have some NOS inside door handles & window cranks..the cranks are what I would call a B grade...chromes fine..but the ***** look a little chewed for lack of a better term...
I do have a couple pieces of NOS 65-66 side trim...no hood or cowling though.
I have lots of dash ***** for 61-66, good used, all come with clip or set screw depending on the ****, all are with inserts as well. I do have a couple of loose inserts and a couple ***** w/o inserts as well..
heater ducts for 61-66
heater grilles, speaker grilles, radio speakers, radios(untested), radio *****, Custom Cab clusters(65-66), dash bezels for round speedo type trucks, 61-66
The above heater grilles, etc is for all 61-66 except as noted. Radios will work in later trucks as well.
I have lower dash **** trim bezel for 61-64 CustomCab trucks as well.
I have lots of RH armrests in various colors for 61-66...tan, gray, blue as well as a green one I believe...I would need to look for lefts if you need one. I also have the wood spacers behind the plastic door panels as well as original armrest attaching hardware.
Door pouches and trim rings for 61-66.
I have door and vent window glass...vent glass would be for glass only as most are in bad frames needing repair. Door and vent glass is all OE pieces, so if you are seeking date coded pieces, let me know...VERY CHEAP as i want the glass GONE!!!
NOS FE Exhaust heat riser valve, 65-67
65-66 'heat' /'temp' cables & ***** with mounting plate for Deluxe Fresh Air heater.
65-66 FE throttle cables...
64-67 Clutch pedal/equalizer shaft relay rods...several...most have service part tags on them.
Fasteners fasteners fasteners!!! Lots of tailgate specific as well as trim screws Several tailgate handles(1 chrome) as well as the escutchion for tailgate handles as well.
I also have lots of the headliner trim that fits 61-66 trucks but was used primarily on 64-66 Custom Cab trucks.
Padded visors for 61-66, I also have one very nice original cardboard sunvisor as well for the same years.
If you, or others you know need E series stuff...i have some early first and 2nd generation parts and trim as well...no drivetrain/brake parts unless it would interchange from the F series trucks.
As always, if theres something you need but dont see mentioned, inquire within.
- cs65
  #173
Old 08-20-2012, 11:15 PM
low64's Avatar
- cs65
red 1st, back 2nd....lemme know what you want for em, and how to pay
  #174
Old 08-21-2012, 10:27 PM
How much for a door pouch with trim ring, plus how do you prefer to be paid?
  #175
Old 08-28-2012, 12:21 PM
pwielage...I do hace the door trim 'C' molding as well as the door pouch and trim ring you inquired about...I left you a message in the visitors section regarding trim a couple of days ago but havent heard back...post your contact info and I will get ahold of you.
low64...email me contact info and we can discuss the parts further.
I've not heard from you jazz regarding what you inquired about...
let me know guys:-)
- cs65
  #176
Old 08-31-2012, 09:13 PM
f10065owner f10065owner is offline
f10065owner is starting off with a positive reputation.
Lots of 61-66 parts...body parts, trim mostly...heavy in 65-66 stuff...dash bezels or clusters, tail gates, door glass, switches and bezels...I also have an undrilled hood...no side trim on it ever...I also have a couple of radios(untested) original dash speakers, dash pad trim, headliner trim, etc etc...
73-9...I have a left grille insert for 73-5(?) and a left for a 76 as well(black paint around headlight area.
I have a pair of 78-9 headlight doors and a complete grille shell, insert and headlight door setup...a dash pad...black...tailgate trim panels, a few pieces of race trak trim and some of the big side moldings with the vinyl cushion in it. Also have a 78-up type CC type horn pad...
Theres lots more not listed so feel free to ask away...
Im open to trades for NOS 65-6 stuff or NOS 79-91 Crown Vic wagon trim
One thing I am in dire need...NOS LB side moldings...also a mint firewall insulation pad.
I am looking for a 65' f-100 radiator. If you have one can you send me pics and a price? Thanks
  #177
Old 09-03-2012, 08:57 PM
66 ford
im interested in the parts tried to send you other messages not sure you are getting them please send me a price at tjsmuddin@hotmail.com
Thanks
Jazz
  #178
Old 09-04-2012, 04:30 PM
clinkfield clinkfield is offline
clinkfield is starting off with a positive reputation.
Do you have a right outer fender for a '66? (I see that someone asked for a right fender on 8/14. Just confirming ...)
  #179
Old 09-04-2012, 09:31 PM
kylesandy64's Avatar
kylesandy64 kylesandy64 is offline
kylesandy64 is starting off with a positive reputation.
I need the trim for the upper door to go In the dentside of a 79 f150, if you have it email a price and picture at kylemsandy64@gmail.com
  #180
Old 09-04-2012, 09:37 PM
No RH fender...only LH for 61-66
i sent you an email jazz...did it end up in the bulk mail possibly ?
I do have an upper molding for the dentside...are you needing with or w/o the rub strip ?
- cs65
Closed Thread
Tags
61, 6166, 66, f100, ford, front, grills, lower, molding, parts, race, ranchero, suspension, track, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Lots of '73-'79 Parts - Parting out 3 1979 F350's EndorphinJunky Ford Truck Parts for Sale 26 01-12-2017 02:58 PM
66 LWB For Sale mangorockfish Vehicles for Sale 0 05-31-2016 10:48 AM
73-79 Ford Truck & 78-79 Bronco Parts-NEED SOMETHING?LOOK HERE! 351coupe Ford Truck Parts for Sale 282 02-11-2016 08:01 AM
61-66 Ford truck parts mal68ibu Ford Truck Parts for Sale 13 02-05-2016 10:36 PM
61-66 door latch abe 1961 - 1966 F-100 & Larger F-Series Trucks 0 01-13-2016 02:02 PM
