converting to power windows and locks di I need new interior inserts?
Old 08-19-2011, 02:10 PM
reamer's Avatar
reamer
reamer is offline
Are the holes in the manual windows and manual locks in the same places as the holes for power window and power lock switches?
or do you need new inserts?
reamer
Old 08-19-2011, 02:40 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
You can possibly enlarge and cut the hole for the window crank and make it square, the you will have to make a new hole for the power locks. If you don't have a rare interior color, then I would just find some new panels with the holes already cut.
Old 10-23-2011, 12:13 AM
Ranger350's Avatar
Ranger350
Ranger350 is offline
Check inside your door jam for a hole in your door to run the wires. I thought about doing the same thing but didn't want to take my doors off to drill them.
Old 10-23-2011, 01:56 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
1980 was the one year out that wasn't electrically equipped for power windows and door locks.
The main dash harness has to be swapped or serious rewiring needs to occur to swap them into a 1980.
1981-1986 has provisions in the fuse panel for the add on harnesses.
1990f150dude
06-30-2012 03:47 PM
BigBlueMacDaddy
2004 - 2008 F150
05-02-2008 09:21 PM
parr4
01-16-2006 11:37 PM
Mr. Finch
03-22-2005 09:30 PM
AlecWire
1978 - 1996 Big Bronco
10-05-2003 02:23 AM
Quick Reply: converting to power windows and locks di I need new interior inserts?
