Ficm help
Ficm help
So i did the Ficm test I put volt meter negitve on the negitive side if battery and possitive probe on the screw head closest to the driver side fender when i key the engine there is no voltage also when i start the truck and check voltage with engine running there is no voltage. Is this Ficm totaly bad or am i doing something wrong?
I'd check out the tech forum in the 6.0 thread located at https://www.ford-trucks.com/forums/3...ch-folder.html
I did mine earlier this year when ambient was ~50F and my voltage was dropping down to 32ish with the key on cycle. I pulled it apart and took the board to a electronics shop and they re-soldered it for 10 bucks. It started warming up after that so I guess this fall/winter will be the real test for mine. But the 6.0 forum is probably the best spot for this thread. Helpful guys over there!
-Thor
-Thor
King of the Road 04
11-27-2010 02:06 PM
