Ford says instrument cluster bad. Help!
To the OP, you would need a manual cluster for gas or diesel, which ever you have. I have swapped out clusters in mine (02 XLT) while trying to fix another problem, which ended up not being the issue, so my original cluster went back in, but to answer questions here; the mileage stays with the cluster, but a speedometer shop can reprogram it to match the mileage on your previous cluster, you will also have to watch engine red lines, as they are different 7.3 to 6.0 in the 2003 clusters. The manual cluster will have a voltmeter instead of the trans temp gauge, otherwise the same other than gas/diesel.
#30
*Update*
I bought a cluster that came out of a 2003 gas motor with a manual transmission. It plugs right up and seems to work but none of the issues are resolved (with the exception that the key chime started working).
Called Ford and the parts department will not help me at all with part number look up.
I asked about a VSM and they swear I don't have one. I looked under the dash and bigger than Stuttgart, I see one. The part number is 2C7T-15K602-AG. I gave them the number and they said it has changed some since new but won't tell me what the part number is.
Is it possible that the 2003 dash just won't work even though it is configured the same as my 2002?
Is it possible that the VSM (that does not exist) is the culprit?
I just wish someone would help me without me spending 1,000 dollars!
Kongerup
03-02-2015 01:18 PM
