How many miles are on your 7.3? - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 08-20-2011, 09:09 AM
kupiec20's Avatar
kupiec20 kupiec20 is offline
kupiec20 is starting off with a positive reputation.
i brought it up a few days ago that i found it odd that his OD read over 400. and the fuse issue hasme scratching my head also.
  #62
Old 08-20-2011, 09:24 AM
tshrager's Avatar
tshrager tshrager is online now
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
I know guys are getting 19-20 with 3.55's , but with 4.10's @ 70? I have a hard time with that.
  #63
Old 08-20-2011, 09:30 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Todd, I also have a problem with that. I'm lucky to get 14 driving REAL easy.
  #64
Old 08-20-2011, 09:59 AM
tshrager's Avatar
Agreed Glenn....18 was the best I've seen. Average is more like 16
  #65
Old 08-20-2011, 10:38 AM
Ya, 17 is the best I've seen driving at 50-55. Stock tires, economy chip setting, syn oil, etc. etc. I think alot of people like to inflat their figures but what do I know?
  #66
Old 08-20-2011, 10:48 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
Glenn, I got 20+ milage on a tank. DC area to Outer Banks NC and back. I used a lot of self discipline (cruise control) at 60-65 MPH. I have never gotten that before and haven't since. But I also have not driven with that discipline either. I believe my right foot is a BIG factor in my MPH equation.
  #67
Old 08-20-2011, 01:36 PM
Andy Sullivan's Avatar
Andy Sullivan Andy Sullivan is offline
Andy Sullivan is starting off with a positive reputation.
I'm getting on highway 20-23 MPGs,@ 55 to 63 MPH. Just drive from my home to work which is about 25 miles around trip it at 18-20 MPGs. I don't pull much no more and don't drive hard but once in a while. I have got 24.5 onces after my little bit of up grades and that was in the winter. I have the 81 250 with the 6.6 , 2 barrel carb that gets 10 MPG so I'm not complaining .
  #68
Old 08-20-2011, 10:17 PM
Buck Dharma Fan Buck Dharma Fan is offline
Buck Dharma Fan is starting off with a positive reputation.
I bought mine last year with 235,000 and now I've got 247,000. The PO took great car of it and I take even better. This truck runs so good I don't even care about the mileage anymore.......Oh wait, I've got an E4OD maybe I should worry,.........Naaaaaa!
  #69
Old 08-21-2011, 12:05 AM
ccarrier's Avatar
ccarrier ccarrier is offline
ccarrier has a good reputation on FTE.ccarrier has a good reputation on FTE.
280k and still running like she should
  #70
Old 08-21-2011, 01:04 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
145,000. I just bought it 1,500 miles ago from my neighbor that has had it since it was 4,000 miles old. Slowly working on a hard shift to third and the sagging front end.
  #71
Old 08-22-2011, 09:35 AM
Bill97's Avatar
Bill97 Bill97 is offline
Bill97 is starting off with a positive reputation.
263k. Orginal trans is starting to get me worried. If I spend 2 or more hours on the highway then do city driving it tends to not shift out of first unless I let off the pedal and before the tc locks in the rpms usually rev up for a split second. Once I let sit over night she is fine until my next road trip.
  #72
Old 08-22-2011, 07:46 PM
fixitman1310 fixitman1310 is offline
fixitman1310 is starting off with a positive reputation.
97 f350
i have 2 312,000 and 218,000 both run great
steve n.carolina
  #73
Old 08-23-2011, 02:04 AM
jtblack26's Avatar
jtblack26 jtblack26 is offline
jtblack26 is starting off with a positive reputation.
mine has 439k and the od went back to 300 when it was about to hit 400k was kinda depressing. my doesnt qualify cause i had it rebuilt at 315K + but it woulda lasted a little longer just had the money and it was burning a big hole in my pocket. i wonder if there was a recall on some trucks to maybe fix the odometer problem if it was one?
  #74
Old 08-23-2011, 03:06 AM
bad12jr's Avatar
bad12jr bad12jr is offline
bad12jr is gaining momentum as a positive member of FTE.bad12jr is gaining momentum as a positive member of FTE.
Ive gotten 20 running 65 with 4:10s but Im also running 33s and that was with no cruise. Filled it before I left and filled up when I got where I was going. Also im at 212000
  #75
Old 08-27-2011, 12:04 AM
lud04X lud04X is offline
lud04X is starting off with a positive reputation.
I just rolled over 140k on my 1997 Crewcab long box 4x4. Everything's running the way it should. The paint still looks fairly new. I don't know about 22mpg but it could be possible. On my last trip I had my fiance and camping gear in my truck and I managed 310 miles on the front tank alone. I have 4.10's and 285's on my truck traveling between 55-70mph on the freeway. My truck only has the 6637 filter and the 4" exhaust from the turbo back with no cat. I switched to the rear tank so I can fill the front later and see how much fuel I used to go 310 miles. I'm thinking around 18mpg.
7.3 Excursion most miles First Ford 2004 Excursion - King of SUVs 39 06-14-2016 12:19 PM
Amsoil bypass intervals thinksnow 1999 - 2003 7.3L Power Stroke Diesel 6 09-02-2015 11:37 PM
is there such a thing huckster 1999 - 2003 7.3L Power Stroke Diesel 4 07-03-2015 07:19 AM
oil change 7.3 diesel charlie555 1999 - 2003 7.3L Power Stroke Diesel 20 06-22-2015 10:25 PM
7.3 liter turbo diesel miles diesel boy 1999 - 2003 7.3L Power Stroke Diesel 8 06-15-2006 10:18 AM
Tags
1995, 1997, 247000, 4x4, 73, 95, 97, diesel, excursion, f250, f350, ford, gallon, lifted, miles, rollback, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
