O/T pine sap removal help - Ford Truck Enthusiasts Forums
Old 08-18-2011, 12:12 AM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is offline
fifty-two_f1 is starting off with a positive reputation.
Ok, I need some help getting pine sap off of my truck. It was on there when I got it about 9 months ago. It is extremely hard and will not come off. I want to buff the truck but i would think the sap needs to be off. So have any tricks?
Old 08-18-2011, 12:20 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
I use wd-40 and or gasoline, then wash n wax it. I never had a problem with any paint removal. I drive a white Expedition!
Old 08-18-2011, 11:16 AM
Moe Craig's Avatar
Moe Craig Moe Craig is offline
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
As long as you don't have any chips out of the paint near the sap, I would also use WD-90... WD-90 can get under the paint too, if it finds a path to fallow. How large is the puddle of sap?
Old 08-18-2011, 11:25 AM
Mervy49's Avatar
Mervy49 Mervy49 is offline
Mervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to all
Try a little paint thinner, or believe it or not, margarine will work too and so will coca cola.
Old 08-18-2011, 01:26 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
If it is hard scrape it off with you fingernail or a plastic tool then wipe off the residue with any of the chemicals already listed here.
Old 08-18-2011, 01:27 PM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is offline
BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.
Two words, Jordan. Lacquer thinner. Best thing I've found to use on clear coat. I wouldn't use it on a single stage paint, though.
Old 08-18-2011, 11:04 PM
carnut122's Avatar
carnut122 carnut122 is offline
carnut122 is gaining momentum as a positive member of FTE.carnut122 is gaining momentum as a positive member of FTE.
Clay bar and detailer that comes with the kit. It'll do amazing things for the rest of the finish too.
Walmart.com: Meguiar's Smooth Surface Clay Kit: Automotive
Old 08-18-2011, 11:35 PM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
turtle wax bug & tar remover and rub rub rub
Old 08-19-2011, 01:02 AM
badger_hound's Avatar
badger_hound badger_hound is offline
badger_hound is gaining momentum as a positive member of FTE.
Maybe maple syrup? Like dissolves like, right!
Old 08-19-2011, 07:51 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
As Dale stated ,bug & tar remover and or mineral spirits . DO NOT use lacquer thinner .
best product for removing tree sap svt rules Paint & Bodywork 17 03-08-2011 09:43 PM
Tree Sap on my hood Hybris 1997 - 2003 F150 11 10-09-2009 10:36 AM
Sap removal tips?? Robbgt 1999 - 2003 7.3L Power Stroke Diesel 13 12-09-2004 08:59 AM
Windshield question Daplumma 1961 - 1966 F-100 & Larger F-Series Trucks 12 11-14-2004 07:33 AM
Pine Tree Sap Removal?? LouV14 Appearance & Dress-Up 13 02-23-2003 07:06 PM
Tags
pine, sap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
