Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Missouri Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Missouri Chapter Join Chapter , Leader:tcbofade
  #1 (permalink)
Old 08-17-2011, 03:11 PM
460429_freak's Avatar
460429_freak 460429_freak is offline
Garage is empty, add now
460429_freak is starting off with a positive reputation.
okay need info from big truck drivers
hey this is a question for the 6 door or the 87...looking at a internatioal dump truck (getting junked) any way it has 2 trannys the truck is a 70's model would say 76? the 2cnd trany has ud od and d so it has a underdrive overdrive and drive would be 1to 1 but will it be sycronized where i could put it behind a automatic ? would i be able to start in ud and when i wanted to shift the ud to d put the truck in n and shift the aux tranny or do they only work with stick shifts
__________________
Can't list my Ford's only allowed 300 letters.... to many to list
FORDS always look better when pulling a CHEVY
  #2 (permalink)
Old 08-17-2011, 06:16 PM
*2fords* *2fords* is offline
*2fords* is gaining momentum as a positive member of FTE.
I don't know the answers to your questions, but...
There was a guy in my 4x4 club that has a 60s era f-750 4x4 that had the manual tranny, I assume it's like you're talking about, mounted behind an automatic tranny.
I think the club has a website. www.ozarkmountain4x4club.com there maybe some pictures, or at least you can message them and ask about the truck.
__________________
92 F-150 flairside all stock 5.0 auto 2WD
93 F-250 4x4 flatbed 5.8 auto KnN, throttle body spacer, underdrive pulleys, flowmaster
73 Jeep CJ5 springover axles, reversed front shackles, 304, T-18, lockers front/rear, 4:29 gears, 33s
87 Toyota Tercel Tuner some engine mods exhaust
  #3 (permalink)
Old 08-17-2011, 06:57 PM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.
You're not the first person to do that. I know of guys that stacked manual transmissions, but I never heard of an under/over unit hooked to an automatic. I guess anything is possible with enough time and money.
__________________
Alan Fenstermaker
'79 F-150 300-6, 4 spd. 4x4
  #4 (permalink)
Old 08-18-2011, 11:09 PM
1OldFordMan's Avatar
1OldFordMan 1OldFordMan is offline
1991 Ford F-150
My Garage
1OldFordMan has a great reputation on FTE.1OldFordMan has a great reputation on FTE.1OldFordMan has a great reputation on FTE.1OldFordMan has a great reputation on FTE.
I drove a Mack ONE TIME that had that setup (UD, D, & OD). My memeory tells me it was NOT synchronized, but that was OVER 30 years ago & my memory lies to me about what I had for lunch, so I wouldn't trust it too far.
__________________
Old Rusty '91 F-150, 302, 2WD, E4OD, reg. cab, long bed R.I.P. You was a good truck !!
Bleep '95 Jeep Cherokee. 4.0(?) 6 cyl. Auto., 4WD
BlackBird '86 AMC Eagle wagon. 258 6cyl., auto. 4WD
Pat C. Misery chapter member
  #5 (permalink)
Old 08-19-2011, 04:06 AM
FORD RANGER's Avatar
FORD RANGER FORD RANGER is offline
FORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud of
my dad drove an old white that had 3 trannys in it. he hated that truck because it had three shifters. man thats been 35 years that i know of. and it had a v-8 detroit in it. no power steering either. i think it was a 18 gear.
__________________
jack, slackmaster #6
1996 ford ranger xlt extended cab,2wd,4.0L v6,5spd,3.08 gears, tornado intake spacer, msd ignition,sun super tach2, k&n air filter, nascar oil filter.
iowa chapter member
  #6 (permalink)
Old 08-19-2011, 09:42 PM
Those old twin stick Macks are a whole 'nother animal. The second stick is a range selector. (now-a-days it's an air operated toggle on the shifter.) It was the old Mack straight cut tooth five speed. You shift one through five in low range, then you shift up to high range and shift back to first gear. (which requires two hands to do this. Which hand do you leave on the steering wheel?) By the way, the transmissions are NOT synchronized.
Mack's are finicky trucks, if it didn't like how you put it in gear, it would throw it back at you and try to break your wrist in the process. The plus side is, you could do NOTHING to hurt that trans. I think it was literally bullet proof.
__________________
Alan Fenstermaker
  #7 (permalink)
Old 08-21-2011, 08:12 PM
tcbofade's Avatar
tcbofade tcbofade is offline
1986 Ford F-150
tcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputation
Quote:
Originally Posted by 1OldFordMan View Post
...but that was OVER 30 years ago & my memory lies to me about what I had for lunch, so I wouldn't trust it too far.
I HATE it when that happens...
__________________
Join the Missouri Chapter!
If my Aunt had stones, she'd be my Uncle...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
