Towing Question/ Hello Folks - Ford Truck Enthusiasts Forums
Old 08-17-2011, 03:18 PM
FlatHeadFat's Avatar
FlatHeadFat FlatHeadFat is offline
FlatHeadFat is starting off with a positive reputation.
Hello folks, I've just started browsing these forums and have found many useful articles.
I am the proud owner of a 1952 Ford F1, Flathead V8. It has the 3 speed transmission, and the optional rear end for towing. Ive been rebuilding it piece by piece since I was 15 years old, and now it's time to move elsewhere in life.
I currently reside in Fargo, ND but am relocating to Aurora, CO in a month or so.
I have a few questions about transporting it into higher altitudes. It will be on a flatbed trailer pulled by a 2011 F350 Super Duty.
What do I need to do to prepare for transport? I'm curious if the increased elevation will cause oil or other liquids to expand causing gaskets to blow or even worse, crack.
Thank you so much guys,
Much Love & Stay Truckin'
Old 08-17-2011, 03:32 PM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Welcome. You'll be fine. Just strap it down and that F350 won't even realize it's back there. My F250 SD didn't even burp when I brought my F1 home across about 3 or 4 pretty good sized mountains. Just tighten up your straps, hammer down and enjoy the scenery.
Don't worry about the higher altitudes. You MAY have to adjust the carb. But that's about it in my opinion. There's a member on here named denverslim. He's a really good flathead guy out there who could probably help you out.
Now let's see some pictures!!
Old 08-17-2011, 03:39 PM
Thanks a million!
I'm having difficulty getting them to show up with the insert code and Flickr, so...
Here's my Flickr with a handful of photos on it.
Flickr: flatheadfat's Photostream
Old 08-17-2011, 04:03 PM
Doc's Avatar
Doc Doc is offline
That's a good solid looking truck. That closeup picture of the "8RT" on the head reminded me of a friendly debate that we had here not long ago. A lot of us are pretty much convinced that, even though Ford referred to them as 8RT engines, 8BA heads were used on the truck engines quite a bit up until about 51 or 52. That makes sense considering your truck is a 52. By the time your engine was made, Ford was using the "8RT" heads. Welcome, glad to have you here.
Old 08-17-2011, 08:25 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
I've run mine over most of the northwest mountains and can't say I've ever noticed any problems with lower pressure. Kalispell is only about 3,500' so it's different than mile-high elevations. If you're concerned, when you get there remove the fill plug on the diff and trans and let the pressure equalize. Beyond that I wouldn't mess with anything.
Old 08-18-2011, 12:20 AM
Sweet, thanks for the knowledge!
Old 08-18-2011, 07:05 AM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
isn't there vents on the trans and the rear ends to keep internal presser to neutral ?? I'm still cleaning grundge off of mine but I was shure I had a vent on the trans..
How are our folks around Fargo doing?? birdman1 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-27-2009 09:53 PM
2007 Ford F350 4X4 Drivetrain - CO rositakid New Member Introductions 1 11-20-2008 06:20 AM
How often do you need to change shocks? wickymustang Brakes, Steering, Suspension, Tires, & Wheels 5 04-21-2004 12:27 AM
Powerstroke diesel performance in cold weather eisenhardt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 02-10-2004 04:32 PM
Old Fargos & GM's copeina Ford vs The Competition 1 04-24-2001 09:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
