Tranny/PTO questions - Ford Truck Enthusiasts Forums
Old 08-17-2011, 12:29 PM
Byrd.Dog's Avatar
Byrd.Dog Byrd.Dog is offline
Byrd.Dog is starting off with a positive reputation.
I have a 60 F250 4x4 with a 4-speed which has a PTO on it. It just started leaking out of the PTO shaft seal. I have no plans on ever using the PTO; does anyone know if a block-off plate is available fot it? I'm also having difficulty getting it unbolted from the tranny-there's two bolts right next to the crossmember that are a b*#ch to get to; anybody have any useful tricks? It's looking like I might have to pull the trans completely to get to all the bolts. Can anyone point me to a good thread on removing th etransmission?
Old 08-18-2011, 06:06 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Your truck has a Borg Warner T-98 4 speed transmission, but the parts you need were used in other Warner trans' as well.
On the right (passenger) side of the case...without a PTO, is a block off plate and associated gasket.
BB-7165 .. PTO Cover (block off) Plate / 6 1/4" long x 4 7/8" wide / (6) holes / Available from Ford.
MSRP: $21.57 // FTE Ford Dealer Parts Dept. sponsor PARTSGUYED.COM price: $15.53.
E7HZ-7166-A (replaced B9TT-7166-C) .. PTO Cover Plate Gasket / 6 1/4" x 4 7/8" / .060" thick / (6) 13/32" holes / Available from Ford.
MSRP: $9.68 // PARTSGUYED.COM price: $6.16.
PartsGuyEd = Ed Olson, parts manager of Horizon Ford Truck Center in Seattle (Tukwila) WA
Fill Transmission With PTO Installed?? FireEngineMike 1947 and Older Ford Trucks 2 03-09-2015 04:01 PM
PTO Pump Swap misterfisher 1987 - 1996 F150 & Larger F-Series Trucks 1 12-09-2013 06:13 PM
A/T with PTO - any users? 4444me 1999 to 2016 Super Duty 1 11-20-2012 05:19 PM
4R100 PTO or Non PTO ChunderDownUnder Australia Chapter 19 08-30-2011 10:26 PM
Can anyone give me details on PTO setup? turboner 1999 - 2003 7.3L Power Stroke Diesel 9 12-23-2010 11:15 AM
Tags
block, plate, pto, t98ptocoverplate, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
