9 inch Rear Question 1970 F100
According to the vin, my truck came with a 240 straight 6. I'm trying to figure out whether or not the rear end is original to this truck as it has a 302/FMX in it now. It is a 9 inch but I have yet to calculate the gearing or pull an axle. Does anyone know what gearing I should have, what the options possibly were if any, and whether or not trucks used 28 or 31 spline axles. The truck is a 2wd.
Odds are it is the original rear end. You can pull the numbers on the tag located on the door providing it is the original tag & that should decode to tell you ratio. You could pull the pig and check ratio just to be sure. The ring gear should be stamped. Count your splines when you pull the axles to drop the pig
No, the metal tag is gone. I can tell the pumpkin has been out at one time, theres a decent amount of rtv evident at the splitline. Im still trying to figure out why the driveshaft turns one 1.25 turns when the wheel is turned once. If the other wheel is on the ground that should hold the spider gear engaged with the axle on the other side. The carrier and wheel are then turning at the same speed. Somethings not addong up
Your truck should have left the factory with a 28 spline and likely with a 3.75 or 4.10 ratio.
I have never been able to figure the jack up one side out thing out. If you can get on a garage floor or other flat area, mark one of the rear tires where it contacts the ground, mark the drive shaft at the rear. Hand roll the tire one complete revolution while counting the revolution of the ds. This will give you the accurate ratio.
John
John
131 = Wheelbase
M = Wimbledon White
F103 = F100
4500 = GVW
114 = BHP
3800 = Recommended RPM
71 = District (Los Angeles)
09 Designates a 3.70 rear ratio. You are on your own for trim pkg or options. You can check out the link below for more info.
Decoding Your 1970 Ford Truck VIN - FORDification.com
M = Wimbledon White
F103 = F100
4500 = GVW
114 = BHP
Also I am unaware of any advantage of the 31 over the 28 for daily use. Failure is a topic rarely seen on that issue.
John
Well I had to pull the pinion to replace the O-ring as it was leaking. 47 Tooth ring gear, 19 Tooth pinion = 2.47:1. As I suspected it's not original to the truck. In fact that's not what I calculated based on RPM as around town at 45mph I'm seeing about 1600 rpm... but I take it the convertor is just slipping away... I've yet to take her on the freeway to see how it does but it should cruise along pretty nicely with the 33 inch rear tires but I doubt I'll be doing any towing anytime soon.
