I have 2008 F 350 Turbo diesel, it makes a loud humming noise that seems to be coming from the left side of the motor. Some times it's very loud and pulsing ( almost seems to be harmonic). Any ideas before I call the dealer?
Scott is likely correct, it sounds like your fuel cooler is low. This uses an electric pump to circulate the coolant, and this pump makes a loud noise when it runs out of fluid!
