Front sheet metal removal - Ford Truck Enthusiasts Forums
Old 08-16-2011, 10:39 PM
charger212 charger212 is offline
charger212 is starting off with a positive reputation.
Hey fellas, I'm trying to remove my front sheet metal from my 56 f100. I understand everything that has to come off except for the cowl bolts, like how many are there and where are they. I can see bolts coming through the back of the fenderwell but cant see the heads on the other side. I need to get at my rocker panels to do some welding so I'd like to get it all off. Any diagrams or pics would be of great help. Thanks!
Rob
Old 08-17-2011, 12:14 AM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
I use my parts catalog to see where everything is hidden ,and it will show you what is on top of what for the last bolt you don't see..I'm pulling my 54 apart this winter..that's why I'm looking at catalogs..
Old 08-17-2011, 03:05 PM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
Rob,
I havent personally removed a front end intact but have heard there are 11 bolts holding the front end on. If I had to guess I would say 3 are around or close to the radiator support along the front and maybe 4 on fender at the rear including the bolt mounting the fender to the running board. I would imagine someone who has done this will be along soon to help. This article may be of some help as well.
1956 Ford F100 - Even Gaps All Around - Tech - Custom Classic Trucks Magazine
Old 08-21-2011, 11:18 AM
Thanks! I'll try that
sheet metal question vidaliaman 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-10-2016 01:57 PM
Front Sheet Metal Removal Wayne Waldrep 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-11-2013 01:06 AM
What bolts/nuts/washers to bolt together front sheet metal Schuyles 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 08-27-2012 09:57 PM
Another OBS interior door handle repair PhL0aTeR 1987 - 1996 F150 & Larger F-Series Trucks 4 08-26-2011 11:13 PM
How to take off front sheet metal 48-52? CAPTAIN 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 02-18-2009 01:38 AM
Tags
1955, 1956, digram, end, f100, ford, front, metal, metel, removesheet, removing, sheet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
