Chassis Dimensions - Ford Truck Enthusiasts Forums
Chassis Dimensions
Old 08-16-2011, 10:14 PM
BrizNasty BrizNasty is offline
BrizNasty is starting off with a positive reputation.
Chassis Dimensions
Anyone have a diagram detailing dimensions for a 1950 F68/F3? Something I can give the guys that are gonna straighten the frame on my project?
I have the one from the shop manual just wondering if there was something a little more detailed out there.
The frame damage appears very minor (slight bend in front of front cross member) but unfortunately because my truck hasn't been registered since it was originally purchased new (second owner yaayyy) in order to register it again I have to get an "Out of Province" inspection which is pretty stringent on the frame alignment among other things.
Any help appreciated. Thanks!
Old 08-16-2011, 11:00 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
I've never seen anything more detailed than the factory published dimensions. These frames were very symmetrical, so making sure the rails even and square should do the trick.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
