1970 Ford 2wd 302 transmission C6 to AOD swap
I have a 1970 Ford F100 2wd 302 and I'm switching out my transmission from a C6 to an AOD. I need to know if this transmission will work... Rebuilt Ford AOD Mustang Thunderbird Transmission It had a 10-1/4" tailhousing on it.
There are two different lengths of tailhousings. The longer of the 2 was for truck applications but I'm not sure what the difference really is in the two. Either will bolt up to your 302 just fine.
I did this swap in my '71. Pretty easy over all. The only "fabrication" you will have to do is to scoot the tranny crossmember back an inch or so. Be sure and get your stuff straight on the TV cable installation and calibration. I used Lokars, but it retrospect think I might look into adapting factory Ford cable.
You may need to consider your rear gears in the swap as well. I exchanged my 3.50 for 4.10 gears and they were a blast, and I got increased mileage (14 MPG) out of it as well. I'm trying 3.70 gears now but don't have a feel for mileage yet.
Good luck in your swap!
Same subject:
https://www.ford-trucks.com/forums/1...f-100-2wd.html
Not sure how much clearer a picture can be drawn for the OP on this swap. This is a pretty easy swap as these things go imo....
Rusty_S
27
03-12-2019 10:30 PM
77429highboy
03-07-2013 02:43 PM
machin3
05-04-2010 01:12 AM
53OlderThanMe
09-08-2008 09:05 AM
