89 f250 doors fit 86 f250 - Ford Truck Enthusiasts Forums
Old 08-16-2011, 12:21 AM
davehaynes davehaynes is offline
davehaynes is starting off with a positive reputation.
just wondering if 89 f250 doors will be a direct bolt on to my 86 f250
Old 08-16-2011, 09:45 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
They bolt on, but there is some slight difference in the way the windows look, I keep forgetting what it is though.
Old 08-16-2011, 12:37 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
The window track between the vent and main window is wider starting in 87 and the holes for the trim panels are in different loctions. The 89 also has the vent louvers in the back edge and a grille below the main trim panel. If you have the lower trim pockets, the later ones have a grille in them tha matches the one in the door.
Old 08-16-2011, 11:49 PM
cool both my doors have bullet holes in them
Old 08-17-2011, 01:11 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
The guts from one door is completely swappable for the other though.
If you want 1980-1986 door panels and windows as example, it's simple to add them.
'89 F250 to Newer Front End? 427ford 1987 - 1996 F150 & Larger F-Series Trucks 4 06-02-2015 01:16 PM
Oldie but goodie Pigfarmer05 New Member Introductions 2 12-15-2014 03:42 PM
86 f250 spindle nut, help! 89laredo 1999 to 2016 Super Duty 1 08-30-2014 01:01 PM
Dana 50 Drop Bracket's cliffordingles 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 38 08-30-2014 04:55 AM
Good trade for a bronco? Shwan_89HD 1978 - 1996 Big Bronco 6 04-03-2014 11:45 PM
Tags
1986, 1989, 1996, 250, 86, 89, door, doors, f150, f250, fit, ford, panel, truck, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
