12v power outlet near Aux in not working. - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 08-15-2011, 09:50 PM
hjsimpson's Avatar
hjsimpson hjsimpson is offline
hjsimpson is starting off with a positive reputation.
Does anyone know if there is a fuse for the 12v power outlet located under the climate controls.
Mine is no longer working.
Old 08-16-2011, 12:49 PM
mpm32 mpm32 is offline
mpm32 is starting off with a positive reputation.
In the engine bay there is a fuse block in front of the fan shroud.
There are fusible link fuses in there. Look for the 20A fuses, I think it's #51 or 52, maybe #10. You can see which one it is since these fuses have a window on the top.
Be prepared to pay $3.50 to $5 per fuse.
I just had to replace three of mine since a power inverter I was using blew 3 of my 4 12v power points.
Old 08-19-2011, 01:10 AM
hjsimpson's Avatar
That was it...thank you!
Old 08-19-2011, 08:20 AM
no problem
Old 08-19-2011, 12:39 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Quote:
What fuse was it if you don't mind me asking?
Old 08-19-2011, 03:47 PM
hjsimpson's Avatar
Quote:
Don't mind at all! It was #52.
Old 08-19-2011, 03:59 PM
berry1234's Avatar
Thanks.
Old 08-19-2011, 08:07 PM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Would be great if I could put a relay & fuse there so the outlet would be dead with the ignition OFF.
-- Chuck
12 volt outlet constant power Indslpwr04 2009 - 2014 F150 3 08-20-2016 08:34 AM
rear 12v outlet not working rkeith213 2009 - 2014 F150 1 08-31-2015 02:16 PM
cigarette lighter and horn problem Lewis90i6 1987 - 1996 F150 & Larger F-Series Trucks 0 11-19-2013 10:34 PM
2008 F350 power seat wiring question Shogun6 1999 to 2016 Super Duty 2 05-07-2013 02:57 AM
12v outlet and Cig outlet legionx 2004 - 2008 F150 4 01-04-2010 11:28 AM
Tags
2007, ciggeratte, escape, expadition, expedition, f150, ford, fuse, lighter, outlet, power, size, wont, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
