Looking for the fuel pump on a 96 E450 bus.
Got roped into messing with a non running E450 bus with a gasser V8. It sounds like it wants to fire, so, I'm assuming that it's a fuel problem. Most importantly, I'm not hearing a fuel pump run when I turn on the key. First off, is there a fuse that might blow? Our maybe a safety shut off switch? And if it is the pump, since I only saw the filter on the inside frame rail, is it safe to assume that the pump is in the tank????
Thanks in advance for any insight.
32MTXSHO
04-25-2004 09:30 PM
