1973 Camper Special and needing better MPG - Ford Truck Enthusiasts Forums
Old 08-15-2011, 06:22 PM
nicenidaho nicenidaho is offline
nicenidaho is starting off with a positive reputation.
Question 1973 Camper Special and needing better MPG
Hello. First time to post. I have a 73 Camper Special with 390 and getting 11mpg at best. To keep this beauty on the road I need better mileage. I've been advised to swap for a 460 EFI with AOD transmission. Has anyone tried this and got better mileage to make this swap worth the effort and costs?
Old 08-15-2011, 07:59 PM
jgoodman6891's Avatar
jgoodman6891 jgoodman6891 is offline
jgoodman6891 is gaining momentum as a positive member of FTE.jgoodman6891 is gaining momentum as a positive member of FTE.
390FE & getting 11mpg?!@#! I would NOT complain about that one bit. Swapping in EFI & overdrive transmission would help.
Old 08-15-2011, 08:39 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Improve the engine's efficiency with headers, dual exhaust, and dialed-in tuning for more HP and torque. An open element air cleaner and K&N filter is with a few more HP - even on a 2bbl.
Next up is a lower (numerically) rear gear... something like 3.00:1... The alternative to gearing down is an overdrive. Now we're talking a TKO-500 and 4.10 rear gears...A 0.68 overdive will net a final drive ratio of 2.79 which is perfect for freeway flying.
Remember to do an ROI (Return on Investment) analysis to figure out how many miles you need to drive before it is paid for.... At $3.50 per gallon and 11 MPG, that's 31.8 cents per mile. Assuming 16 MPG, it's 21.8 cents per mile. ... and miles add up.
Old 08-15-2011, 10:54 PM
meborder's Avatar
meborder meborder is offline
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
Im no expert on 390's, but i can tell you that i dont think a 460 is the answer to your quest for mileage.
ive got 4.10's and the best i've done is 10.25mpg at 65 unloaded. no overdrive though.
it would be possible to find a 460/AOD combo out of a later truck or motorhome, but 10mpg is still a pretty common number for those as well.
soooo ... perhaps you could spend that money on a gear vendor's overdrive?
save the work of swaping motors and trans and still get the OD. set you back $1500 ish?
another option would be fuel injection. Summit has a self learning FI kit for about $1700. that would likely net you some gains as well.
not trying to rain on your parade ... just saying .. they are big old heavy trucks with big old heavy motors .... and they likes them some dino juice ....
good luck!
Old 08-15-2011, 11:47 PM
HIO Silver's Avatar
EFI.. a high-dollar item and the last thing I plan to do with my 70 bump after the exhaust and TKO-500/rear gear. It's still up in the air on whether to go with Professional Products' Powerjection or the FAST XFI.. decisions, decisions, decisions.
Old 08-16-2011, 12:25 AM
73ferdf250highboy 73ferdf250highboy is offline
73ferdf250highboy is gaining momentum as a positive member of FTE.
the best my 390 gets is bout 10-11mpgs. she runs real good on a 750cfm q jet.
im on 36x14.50x16.5 w/4.10's
yer best bet is to buy a commuter car.
my .02
kurt
00 f350 7.3 4x4 scsb
99 f350 7.3 4x4 cc lb drw
73 f250 390 highboy np 435- 205
03 getta gli
98 passat
90 corrado
Old 08-16-2011, 12:44 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
11mpg is pretty good!!! FYI a 460 EFI gets about the same!!! Consider replacing the torque converter with a fuel miser from hughes! I picked up 1 to 2 mpg and it really helped.
Old 08-16-2011, 08:05 AM
eric72xlt eric72xlt is offline
eric72xlt is starting off with a positive reputation.
I think 11 miles per gallon out of an f 250 camper special is pretty good. I have an f 100 2 wheel drive that only get 11 and a half. My buddy's 04 f250 with a 5.4 and or only gets 12! If you want mileage I would go with the cummins diesel swap That I have read about on these forums.
Old 08-16-2011, 07:29 PM
Thanks for the good ideas and advice
A lot of good responses...thank you everyone! Changing motors made me cringe since I have only 40K on rebuild. However upgrading the Torque Converter, installing headers, K&N and maybe a good intake manifold would be good to try. Since I'll have the transmission off why not install an AOD? I read the '92 or early '93 is the best for that run. Many upgrades were incorporated to beef it up. Wouldn't that be better than installing an overdrive unit? I believe they are shy of $3K
Old 08-16-2011, 07:31 PM
There is ZERO OD transmissions that bolt up to the FE engine you have with out a lot of $$$ and time.
Old 08-16-2011, 07:51 PM
haven't heard of this...is it manual trans or bolts up to the C6?
Old 08-16-2011, 07:55 PM
I See
Excuse me, I see understand what you meant...any OD will be time and expense.
Old 08-16-2011, 11:49 PM
meborder's Avatar
Quote:
IIRC ... the 92 ish AODs where the strongest made in production. In particular the ones found in the HD trucks, or behind the 351w in the F150's had a 2" OD Band, and are generally regarded as the best of the salvage yard find.
AOD Performance Products - Baumann Electronic Controls
BE Controls has a wealth of information available on the AOD/4R70W. They can be made quite bullet proof.
Ford FE to Ford AOD transmission adapter kit
a quick search showed the above site to mate the two together.
One nice thing about doing an AOD swap is the factory column shifter will work because the AOD only has OD.D.1 on the shift pattern. Where by, for racing or towing 2nd can be held by throwing the shifter down into 1 at speeds above 20mph or so. You'd be wise to limit doing this, however, unless you purchase the "fix" from BE Controls (or someone else), because when you hold second in this fashion you WILL lose your OD at somepoint. Ask me how I know ....
if the shifter is thrown into 1 above 20mph or so, the trans goes into second, once the speed drops below that threshold it automaticaly drops into 1st. for controlled upshift you have to start in 1,then bump up to D to allow second, then throw back down into 1 to hold second, then bump back into D to allow third. It's kind of fun once you get the hang of it, but doing so will cost you OD eventually, unless you fix the valve body. again, ask me how I know ...
anywho ... it's a worthwhile swap if you can make it work .....
Old 08-17-2011, 12:04 AM
To make an AOD swap work you will need an adapter Ford FE Transmission Adapters its 1500.00 by itself!
Old 08-17-2011, 12:16 AM
meborder's Avatar
Quote:
Transmission Adapter Pricing
850 here .... still a lot of coin ....
makes your return on investment calc harder to pan out.
I think this is something you'd probably do just because you wanted to ... I dont know that it would ever pay for itself.
i'd do a fuel injection kit from summit before i did this swap.
but it can be done ...
Worthwhile axle swap? Camper Special Gene 1961 - 1966 F-100 & Larger F-Series Trucks 10 08-18-2013 05:48 AM
Gotta Truck Camper. Need Advice El Camino Man Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 11 05-28-2013 09:34 PM
WTB Super Camper Special 1973-1979 71 Sport Custom WTB - Ford Trucks & other vehicles 18 02-05-2013 06:30 AM
New 66 F250 Camper Special HillBillyBuddha 1961 - 1966 F-100 & Larger F-Series Trucks 33 12-26-2012 05:42 PM
1974 F350 Super Camper Special Transmission/Rear End Questions. green_lightening 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-28-2010 08:36 AM
Tags
1972, 1973, camper, caper, f350, ford, gallon, gas, international, mileage, miles, mpg, pickup, special, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
