'70 F100 CV IFS/TBird IRS Build
#76
#78
David.
#79
#81
#82
[/QUOTE]
The blue "68 belonged to a friend of mine & is all stock. These pics are before the dropped springs. Have more pics coming of the fender scoops and the drop springs. We also got rid of the wipers. Welded in a portion of the factory grate. I took 2 leaves out of the rear which dropped it 3". Poor thing had a 7 1/2" rake. Hopefully the rear suspension will go in soon. Heart attack slowed me down a bit.[/QUOTE]
which leaves did you pull from the rear springs or doesn't it matter, fantastic build will be following this thread
#83
The TBird has struts and would require building an upper strut mount. In other words the inner fender is part is the front suspension on the TBird. I have seen a thread somewhere where someone did use the TBird front suspension but don't remember where. It was quite awhile ago. I would probably say amount of fab work. The CV just makes for a cleaner install IMHO.
As to a Tbird donor car. Unless you are getting the car dirt cheap or are using way more than I did from a Tbird it is more cost effective just to buy the IRS. I paid $125 for the IRS I used. With it I got the set of wheels and the pwr rack. I was originally planning a MII IFS until I learned about the CV swap. With the MII swap you can use the TBird rack. The same goes for a CV. I paid $250 for the IFS. I wasn't using anything else from a CV so to me just buying the IFS already out of the car was by far most cost effective.
I would bet if you did a search for TBird IFS swap you might find that thread. I can't remember what type of truck it was but I am thinking it was a bump. I may go a looking. If I find it I will send you the link.
#84
The blue "68 belonged to a friend of mine & is all stock. These pics are before the dropped springs. Have more pics coming of the fender scoops and the drop springs. We also got rid of the wipers. Welded in a portion of the factory grate. I took 2 leaves out of the rear which dropped it 3". Poor thing had a 7 1/2" rake. Hopefully the rear suspension will go in soon. Heart attack slowed me down a bit.[/quote]
which leaves did you pull from the rear springs or doesn't it matter, fantastic build will be following this thread [/quote]
I pulled #2 and #4 from a 5 leaf pack. Have no idea what it will do to your payload capacity as I haul nothing more than a case of beer or groceries in this truck. I have a '90 4x4 that I use as my truck.
#85
I wont be hauling much more than camping gear for shows, I've got 7 leaves with some sort of assister's on top, the assister's will be the first to go. the ride is a bit harsh at the moment. also how hard is it to dismantle them and did you have to modify the central pin?
#86
#87
If your truck is all rusty underneath you will probably want to replace the U Bolts. You will need to add some washers for spacers to your U Bolts as you won't have enough thread to run the nuts all the way down. New U bolts would cure this as well providing you bought custom from a spring shop. The U bolts are 9/16".
Do the other side and you are done. No idea on your extra leaves.
#88
Thanks for the info. I didn't think about just buying the IFS/IRS by themselves. The only thing I would have used from the T-bird other than the suspensions, was the front leather seats. But to pay for a whole car just for seats and suspensions, doesn't sound cost effective.
#89
#90
I know what you mean. I think we are just over $4000 in our truck to date. We are budgeting $5000 for additional body mods & paint. Then of course we have the wiring harness, wheels/tires and engine/trans build. We are hoping to come in between $15K - $20K total which I don't think is bad at all for what we will have when finished.
