1948-50 vin
Old 08-25-2011, 05:38 PM
markuth's Avatar
markuth
markuth is offline
1948-50 vin
My vin last 6 are 454539. Is this a 49 or a 50?
Old 08-25-2011, 06:56 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,450 Likes on 1,397 Posts
Assuming the first two numbers are 97 or 98, it's probably a '50. I seem to recall our 49-50 historians mentioning the changeover occured near the 300,000 mark. Do you have numbers stamped on your firewall? In that string should be a date code. See if you can find that. Post any numbers you find here.
Old 08-25-2011, 07:37 PM
markuth's Avatar
markuth
markuth is offline
vin 48-50
Hi there!
Thanks for your reply.
the rest of the vin is 98RC454539.
The same # appears on in both places on the truck.
Regards,
Mark
Old 08-25-2011, 09:40 PM
52 Merc's Avatar
52 Merc
Which both places are you talking about? Your vin should be stamped on the right side frame rail, on a tag riveted to the firewall, and on a tag located on the inside of the glove box door. The numbers I was referring to are actually stamped into the sheet metal of the upper center of the firewall itself, near the cowl seam, not on a tag.
Old 08-26-2011, 07:33 AM
harleymsn's Avatar
harleymsn
harleymsn is offline
Unless it was built in Norfolk, Va, in which case it will be all the way over on the driver's side.
Old 08-26-2011, 03:16 PM
mtflat's Avatar
mtflat
mtflat is offline
the build code has been reported anywhere on the firewall - left, right, above the seam and below it. some don't have a stamping at all.
Gotta love Ford's consistency..... grin
Ribs
03-15-2016 04:13 PM
wrestler11
06-20-2011 01:54 PM
Voh
12-12-2006 07:53 PM
John - NNY
03-13-2006 08:13 AM
f600tanker
11-02-2003 07:48 AM
Quick Reply: 1948-50 vin
